CPUBalance Pro – Restrain CPU Hogs to Improve PC ResponsivenessCPUBalance is near-Freeware (Freemium) that contains
ProBalance, Bitsum’s proven and real-world demonstrable technology to retain system
responsiveness during high loads, or even save you from a hard reset during a worst-case scenario.
This application is a SUBSET of the technology found in
Process Lasso. It is designed to work with or without Process Lasso present
If you already have Process Lasso v8, you do not NEED this application. However, it can complement Process Lasso by running along-side it, where it
integrates perfectly
You can install both Process Lasso and CPUBalance on the same system with no problems. Both apps will work together. They both use the
same core engine, ‘processgovernor.exe’. So if you already have Process Lasso, this just extends the user interface and system tray icon, perhaps a newer
core engine, and additional ProBalance tweaking
So, let's ask what are the benefits you will get from using this app?- Newer tech than is in Lasso v8, (Lasso v9 will eventually have that tech).
- A different system tray icon for specific ProBalance interactions.
- A new Frequency of Action (Restraint) metric, which is pretty cool.
- Note that these features are all planned for Process Lasso v9 – so no removal or reduction of features here!
Homepage:https://bitsum.com/portfolio/cpubalance/Current version: v1.0.0.20
Release date: Jan 15, 2017
Download:32 bit version:
https://bitsum.com/files/cpubalancesetup32.exe64 bit version:
https://bitsum.com/files/cpubalancesetup64.exeProBalance settings:
Bitsum’s ProBalance Optimization Algorithm:ProBalance ‘fixes’ system responsiveness if it is a background process out of control, or as soon as you click away from the foreground process. You have to
click away only because of the default ‘foreground exclusion’ to prevent ProBalance from acting on something important to you.
ProBalance is extraordinarily useful to the following users:- Multimedia editors. Sony Vegas and other software can bring your PC to a crawl when saving.
- Those who do a lot of multi-tasking and have a lot running in the background.
- Gamers, VOiP, and other real-time users who want to avoid micro-lags.
- Those who have high sustained CPU loads, and want to actually use their computer in the meantime.
[video=youtube]https://www.youtube.com/watch?v=gFAUVhC5LFI[/video]
Full details about the ProBalance algorithm can be found here:https://bitsum.com/how-probalance-works/Purchase:https://bitsum.com/buy-cpubalance-pro/Free versus Pro:At
present, nothing except your name. That’s right, it is 100% free right now. That may change going forward with certain feature restrictions or such.
What is New?v1.0.0.20 – Fix language detection issue in last build
v1.0.0.18 – Fix critical future update issue due to identical event names accidentally used (copy and paste accident corrected before it became too much of an issue)
v1.0.0.18 – Add new language auto-detect in-product
v1.0.0.18 – Update languages
v1.0.0.14 – Fix rare issue with co-install of Lasso could cause two instances of CPUBalance governor in some sessions to be running.
For the whole revision history, please visit here:https://bitsum.com/portfolio/cpubalance/I would like to thank Jeremy and Bitsum Team for sponsoring this giveaway exclusive for our forum membersDetails:Number of licenses: 10
Validity of license: Lifetime
Value of license: 44.95$
Entire Home licenses
Giveaway Duration: 20 days
Winners selection: Random .org
Source:
http://www.promo2day.com/showthread.php?tid=13820
