  • Total Topics: 11549
  • Online Today: 1349
Author Topic: Windows 10 Netbios is always disabled, how enabled it??  (Read 6176 times)
casper68
Re: Windows 10 Netbios is always disabled, how enabled it??
« Reply #11 on: 05. June 2017., 13:48:59 »
Thanks for you time and for your reply, but nothing is change   >:( >:( >:(
Below the screen where for wmic command it is enabled, but in details of network interface is disabled.
it's absurd.
« Reply #12 on: 05. June 2017., 15:06:56 »
Nope, take a look... you are using interface 22 and you are probably (and most) confisuing it with interface 10...
Did you try the wmic to enable it on interface 22?
casper68
« Reply #13 on: 05. June 2017., 15:51:49 »
Yes I try on interface 22 but if It is not connected you don't set NetBios Options.
Dell Precision 5510 have a thunderbolt port ( USB Type-C) and I have the thundelbolt dock wd15 and dell adapter da200.
Both refer to the driver Realtek USB GbE Family Controller, but with two interface:
Dell Dock wd15 interface 10
Dell Adapter da200 interface 22
The problem is if I disconnected the ethernet (dock or adapter) and I connect the WIFI with other driver ( Intel ac 8260) is the same, then I think that is somethings of Windows on local.
« Reply #14 on: 06. June 2017., 00:19:32 »
Well, I stumbled upon http://www.tomshardware.com/answers/id-3241432/netbios-tcpip-disabled-matter.html
At the last reply, they solved it by performing a "network reset". It's worth a try I beleive
casper68
« Reply #15 on: 06. June 2017., 16:26:21 »
Thank for all,I also tried this but nothing.
At least I'm not the only one who has this problem.
https://social.technet.microsoft.com/Forums/en-US/1add7d03-2bc0-4d1e-9248-fef090d9ba0e/anyone-else-notice-the-network-issues-with-windows-10-creators-edition?forum=win10itpronetworking
There seems to be something related to the latest update of windows 10 creators update.
Re: How to enable NetBios after Windows 10 creators update
« Reply #16 on: 18. June 2017., 22:05:20 »
Hi,
First of all, my question, did you resolve this problem till now ??
If NO, consider option to manually reset your Internet Protocol (TCP/IP) settings:
1. Press Windows+R on the keyboard to open the Run window. Type netsh int ip reset resetlog.txt and press Enter.
When you run this command, it'll rewrite your computer's registry keys use for TCP/IP settings. This achieves the same result as removing and reinstalling the protocol.
2. Restart your computer.
Note: Before restarting, please save any open files and close all programs.
After, that check NetBios status (try to turn it ON/OFF) & DON'T FORGET to provide us result.
cya later,
casper68
« Reply #17 on: 22. June 2017., 11:04:49 »
Hi thanks for your help.
I try to manually reset as you write, but nothing change.
