  • Total Topics: 16672
  • Online today: 1753
Guests: 1745
Total: 1747
Author Topic: Process Lasso v9.0 Review and Giveaway (10 Lifetime Licenses)  (Read 2037 times)
tarekm
With daily use of your computer, your system is getting slow and sometimes unresponsive or freeze. Most of the users will need to increases system responsiveness and helps to prevents system stalls. We have a very good and professional solution for you. Process Lasso is an automated Windows process management and optimization utility. It will manage the programs running on your computer using ProBalance technology. This built-in technology uses a specific proprietary algorithm which dynamically adjusts the priorities of running programs on your system. Some processes are given higher priority access to the CPU than others which avoid system stalls whatever the processes you are running.
Using the program, you can tweak how programs are run. Process Lasso also offers a number of unique and helpful capabilities such as default priority classes, default CPU affinities, disallowed processes, keep running processes, per-process Power Profiles, a process watchdog, and process instance count limits. These features give you the ability to control how programs utilize your computer’s resources based on automatic settings. With the use of process lasso, you will decide exactly how you want your processes to run.
Home Page:
https://bitsum.com/
Current version:
   v9.0.0.348
Release Date:  05/20/17
Download:
32 bit: https://bitsum.com/files/processlassosetup32.exe
64 bit: https://bitsum.com/files/processlassosetup64.exe
Giveaway:
https://www.promo2day.com/showthread.php?tid=16222
