  • Total Topics: 16978
  • Online today: 137655
Guests: 134723
Total: 134725
Author Topic: Windows 2008 R2 + VSE 8.8p8 trouble  (Read 19632 times)
0 Members and 57 Guests are viewing this topic.
ssl
« on: 04. June 2017., 22:25:16 »
Hi. One month ago my b2b admin installed VSE8.8 p8 in the Win2k8. Throught some days Explorer doesnt work correct and we have not server access via RDP. Also couldnot start any MMC. Any idea guys server recovery?
Re: Windows 2008 R2 + VSE 8.8p8 trouble
« Reply #1 on: 05. June 2017., 15:04:28 »
Looks like a misconfigured Access Protection Policy, is it managed via ePO? If it is, you can update the policy there and push an agent update, then you should be able to access in ~5 min. If it isn't, then you need physical access to the machine, or some sort of remote console (iDRAC for Dell, iLO for HP, etc..)
ssl
« Reply #2 on: 05. June 2017., 21:18:44 »
VSE has been installed as standalone without ePO. I've server access. I could login into server but workplace is inaccessible, also C-A-Del dont working.
« Reply #3 on: 06. June 2017., 00:11:14 »
urgh... can you get CPU usage stats?
ssl
« Reply #4 on: 13. June 2017., 08:44:51 »
CPU, memory, HDD is ok. After run MMC for disable Mcafee services I get black screen and logoff. Now I cant login into server. Next login is possible when  server will restart. May be that VSE damaged SYSVOL folder?
« Reply #5 on: 13. June 2017., 18:11:17 »
It shouldn't be the case, when server restarts can you open VSE console? If you can, take a look at Access Protection Policies. First try disabling access protection, the look the policies and re-enable it when its properly configured.
« Reply #6 on: 18. June 2017., 22:37:32 »
Hello,
Just want to check, did you resolve this issue ?? :police:
cya later!
