  • Total Topics: 16942
  • Online today: 137698
Guests: 133557
Total: 133558
Author Topic: SpyCleaner Platinum v.9.8  (Read 8507 times)
0 Members and 10 Guests are viewing this topic.
amko_sa
    • Newsapp IT support Portal
« on: 21. May 2007., 22:03:47 »
http://www.tdfast.com/software/download/SpyCleanerPlatinum9.8TrialVersion.exe
SpyCleaner Platinum description:
Spyware are those software which send your personal data like, your browsing behavior, your computer's system configuration, Software installed on your computer and a lot of other information depending on the nature of the spyware, to their companies without your approval or knowledge. It is virtually impossible to avoid them since they are very clandestine in nature and get hardly noticed by a user. The data sent by them can be harmful for your privacy as it may include your address, email and other personal information.
Spy Cleaner Platinum works as a guard for you and keep check on these spyware. It assists you to check your computer for any spyware and if found removes it. Spy Cleaner Platinum has a huge database of spy components which infects the system. Through this database Spy Cleaner Platinum accurately recognizes and removes these components from your system.
Spy Cleaner Platinum has the option to Backup the components removed incase you need them. This case might arise if these component are integral part of another software you are using.
Spy Cleaner Platinum has many utilities which not only help you recover from the damage done by Spywares but also help you to prevent them. Spy Watcher which is a helper application of Spy Cleaner Platinum monitors in real time the critical areas of computer which can be attacked. It immediately inform you about these changes and repair them accordingly.
Spy Cleaner Platinum has also a reporting tools which generates a detailed report of all the areas which can be affected most of the spyware. This report helps our support people to tackle with unknown and new spywares.
Spy Cleaner Platinum shows you the report of scan in a very organized way so that you can correctly and easily remove these components. It also provides you the option of saving log file of the scan result and file deletion for future reference.
b_gates
Re: SpyCleaner Platinum v.9.8
« Reply #1 on: 13. October 2009., 01:08:19 »
thanxxxxxxxxxxxx
