Tesline-Service SRL has developed a convenient solution for replacing your system password with a USB flash drive. Rohos Logon Key lets you log into your Windows without scrambling for passwords just plug in a USB flash drive whenever a password is required to log in or unlock desktop, and you’re in.
It is a two-factor authentication solution that converts any USB drive into a security token for your computer and allows you to access Windows in a secure way with a USB token, replacing the Windows login.
You don’t need to remember and manually type in your Windows password. Enjoy fast and automatic login into Windows. User can be automatically logged into Windows as they insert the device into the USB port, it is not necessary to type in your password. In addition, there will be an automatic windows lock when user unplugs USB Key from computer and higher security with PIN code for USB Key
Homepage:
http://www.rohos.com/products/rohos-logon-key/Current version: 3.4
Release date: July 27, 2017
Download:
http://www.rohos.com/rohos_welcome.exeInstallation:
After you download the installer, double click and follow on screen instructions till the program is installed on your computer
Free Trial:
15 days fully functional free trial
Purchase:
https://rohos.onfastspring.com/rohos-logon-key
Features:
The program Rohos Logon Key provides numerous enhanced features over and above what our competitors offer. It helps you easily re-use your USB flash drive as a protection key and security token for home and office computer.
Regular password-based login can be disabled
As USB Key you may use: any USB flash drive, U3 Smart flash drive, SD/MMC memory card, Aladdin eToken, Yubikey, etc
Automatic login or unlock when USB Key is detected
Automatic Windows lock when user withdraws USB Key from computer. And more options of what you’d like to happen whenever the USB key is removed, such as: Hibernation, activate Screen Saver, Logoff
[Unique] Protects your computer even in Windows Safe Mode login. It is not possible to bypass USB Key security by loading computer into Safe Mode
Emergency Logon that helps to access your system in case you lost USB drive or forgot PIN code
Flexible USB Key options: A single Key can be used to log in into multiple computers – OR – A computer can accept only a single Key for login, ignoring stranger keys
Rohos Logon seamlessly integrates into any Windows configuration automatically choosing authentication modes
Allows to use USB Key to log into Remote Desktop
Read the full review HERE:
https://www.promo2day.com/showthread.php?tid=18369I would like to Thank Rohos Team for sponsoring this exclusive Giveaway for Promo2day users
Giveaway details
Number of licenses: 3
Value of each license: 59$
Validity of each license: Lifetime
Giveaway ends: 28 September 2017
Winners selection: Random.org
Rules Here:
https://www.promo2day.com/showthread.php?tid=18370
