  • Total Topics: 16962
  • Online today: 145328
Guests: 141869
Total: 141872
Author Topic: How to use my bluetooth headphones with HP 15 Notebook PC  (Read 8981 times)
0 Members and 14 Guests are viewing this topic.
krishna88
« on: 10. November 2017., 13:22:24 »
Hi to all,
I am not able to use my headphones with the headphone jack there may be some problem i guess, so I brought some Bluetooth earbuds.
Can anyone tell me how to check if this will work? I am not sure this PC will support them.
Need your help.
Thanks!!
Re: How to use my bluetooth headphones with HP 15 Notebook PC
« Reply #1 on: 10. November 2017., 22:03:27 »
The computer tells that you plugged the headphones?
As for BT Audio, it should work, not flawlessly, but it should work.
grr
« Reply #2 on: 12. November 2017., 05:53:28 »
you can try 3 things
1. check headphone on another device, say mobile
2. see if you have driver installed for headphone
3. use a usb to audio jack converter
If your PC supports Bluetooth, then Bluetooth earbuds should be able to connect to PC.
krishna88
« Reply #3 on: 13. November 2017., 10:16:43 »
Hi,
Thanks for your answers @grr and @jheysen, i will surely check them out.
Cheers!!
jamesd
« Reply #4 on: 11. December 2017., 14:28:21 »
You need to check if your computer has built in Bluetooth in it, if you you may need a bluetooth adapter.
Have a look at this for Win 10.
https://www.windowscentral.com/how-and-why-use-bluetooth-on-windows-10
krishna88
« Reply #5 on: 12. December 2017., 09:13:11 »
Hi @jamesd,
This one worked for me, thanks  :up:
