  • Total Topics: 16748
  • Online today: 2452
Guests: 2452
Total: 2453
Author Topic: LEGACY LIMITATIONS.  (Read 3335 times)
A41202813GMAIL
  • XPOCALYPSE FOREVER !
LEGACY LIMITATIONS.
« on: 17. December 2017., 22:28:21 »
A - HDD SATA Internal 3.5 320GB Model ST3320820NS ( My Main Drive In The Last 8+ Years ),
B - HDD SATA Internal 2.5 300GB Model WD3000BLFS.
I Use XPPRO32Bits.
With ( A ) I Can:
C - Delete And Create Partitions,
D - Write On The Drive,
E - Using The Drive To Boot.
A Family Of Mine Gave Me 2 ( B ) Drives.
F - I Can See The Drives On The Disk Management, But The Only Original Partition Type Is Called GPT Protective Partition And I Simply Can Not Do Absolutely Anything With Them,
G - No Letter Is Even Assigned To The GPT Partition.
Any Ideas Out There ?
Thank You.
LEGACY LIMITATIONS.
Re: LEGACY LIMITATIONS.
« Reply #1 on: 23. December 2017., 14:47:28 »
to my knowledge, WinXP can't use GPT partitions, so you'll need to reconvert the partition table to MBR. You can use a Linux live distro to do that.
A41202813GMAIL
LEGACY LIMITATIONS.
« Reply #2 on: 24. December 2017., 00:28:05 »
I Simulated A New OS Install From Scratch, Using The Original XP CD, And Business As Usual.
Thank You.
LEGACY LIMITATIONS.
