1.Launch iTunes. Make sure you have the latest version of iTunes installed. If not, click the “Help” menu and select “Check for Updates” and allow any available updates to install. Then download iTunes and complete the update. Drag and drop your music files from a folder on your PC into the library section at the top of the left column in iTunes. Also, you can click “File” and select “Add File to Library”, then choose the music files you want to transfer and click “Open”.
2.Connect your iPhone 7 or 7 plus to your PC using its USB cable. Click on the iPhone icon and open the “Music” tab, then check the “Sync Music” box.Check the “Entire Music Library” if you want to sync all tracks in iTunes library to your iPhone, or choose “Selected Playlists, Artists, Albums and Genres” and check the boxes. Then click the “Apply” button, your selected music will be transferred to your iPhone 7 or 7 plus.It’s quick and easy to sync music from your iTunes library to your iPhone’s music folder.
