  • Total Topics: 16978
  • Online today: 137655
Guests: 134552
Total: 134554
Author Topic: EDB to PST Converter Tool  (Read 16635 times)
0 Members and 40 Guests are viewing this topic.
emmawils
« on: 29. August 2018., 13:00:36 »
EdbMails EDB to PST Converter Software which allow you to nicely Recover EDB emails mailbox to PST File as well as repair corrupt exchange server database.It can easily find the EDB location and fix all the issues of EDB file to makes it usable into outlook file. It gives the complete examination of Exchange Databases files to recover and alteration process.This tool can easily export exchange mailbox to PST from Outlook Without distressing the size of Exchange EDB files and easily convert EDB files into PST, EML, MSG, Text and HTML file format with convert all reclaimed Email items into outlook file with along email header, email equities or attachments too. Splitting the generous size of PST file up to 20GB or more during conversion time.
•   Easily converts EDB to PST files &Restore deleted mailboxes directly from EDB file.
•   It is compatible with all MS Outlook 2000, 2002, 2003, 2007, 2010, 2013 and latest 2016.
•   It compatible with all the windows OperatingSystems like Windows XP, Vista, 7, 8, 8.1 and 10.
•   Also, it provides recovery of all the attachments including contacts and calendar.
EdbMails EDB to PST Converter is the only available software which allows you to convert and export Online as well Offline, both, EDB file to PST format.
williamrhodes079
Re: EDB to PST Converter Tool
« Reply #1 on: 07. August 2019., 09:10:50 »
Simply convert the EDB file to Outlook PST by using this most reliable software that instantly fixes all corruption and damaged issues from Exchange and allows every user to convert the Exchange EDB file to multiple readable file formats such as- PST, EML, EMLX, MSG, and HTML. I am talking about the eSoftTools Software which authorizes the user to recover the lost and accidentally deleted items from Exchange Server to new PST file without creating any problem. Try the free demo version of this software from the given link.
Akshay_M
« Reply #2 on: 23. October 2019., 17:29:16 »
Convert EDB to PST Using Exchange Management Shell
Exchange Management Shell provides a command line interface to access the exchange mail database, get its status, and make the required changes in them.
To convert free EDB to PST file, use the following commands in a sequential manner
Step 1: Run the command to get the list of mailboxes in a database.
Get-MailboxStatistics -Database <DatabaseName>
The command will enlist all the mailboxes present in the database.
Step 2: Run the command to export the EDB file to a PST.
New-MailboxExportRequest -Mailbox <MailboxName> -FilePath \\ExchangeBackup\PST\MailboxName.PST
The command will save the mailbox data to a new PST file. But make sure that the destination folder is a shared folder.
Step 3: Run the command to check the status of mailbox export request.
Get-MailboxExportRequest
It will provide the status of the export request.
Step 4: After completing the export process, cancel the export request by the following command.
Remove-MailboxExportRequest -Identity <Name of the export request>
Using this process, you can export the data from a single mailbox.
Hope this helps
Akshay
Rajat Rajput
« Reply #3 on: 18. February 2021., 05:55:18 »
Hi, if you are looking for a quick and easy solution to convert EDB files to PST file format, then you need to have a smart EDB to PST converter tool which is able to convert EDB files to PST, EML, MSG, MBOX, etc. It also supports the conversion of the corrupt EDB files. Data Recovery Solutions has offered the professional EDB to PST converter tool FREE for 1 month to all the users.
For more info, visit - https://www.data-recovery-solutions.com/exchange-edb-to-pst-converter.php
Amit22Richardson
« Reply #4 on: 07. September 2024., 14:04:26 »
If you guys are looking for the best EDB to PST Converter Software, then don’t fall for the fake solutions. Ther are not many ways by which you can get this task done safely. However, an automated tool with the integration of Artifcial intelligence is what users need.
Goldytools offer the Best EDB to PST Converter as per my personal experience. Download the tool & then follow the below mentioned four basic steps to execute the entire solution without any hassles.
Step-1. Launch the Tool & Click on the Add File option.
Step-2. Preview the Mailbox Data Items in this section.
Step-3. Select PST format & Destination Location path.
Step-4. Finally, Click on the Export button to finish off the task.
To explore this tool further, Watch this video clip: https://youtu.be/j1ajijjTYp8
