  • Total Topics: 10987
  • Online Today: 2550
Author Topic: OST to PST software  (Read 8337 times)
ronald007
OST to PST software
« on: 27. December 2018., 11:12:01 »
If you want to convert your ost into outlook then friends Check out this third party OST to PST Converter tool - SoftMagnat which i have been using for long time. this tool offers you to show preview of all the mail objects after conversion. this tool shows the preview in 3-pane structure. In the preview window, you can see the contacts, calendars, journals, and tasks arranged in efficient way. It looks a lot similar to familiar Outlook. This way, it gives accurate conversion results and ease of use. this ost to pst converter tool can Supports MS Office Outlook 2000, Xp, 2003, 2007, 2010, 2013, 2016 and 2019 (32-bit and 64-bit). you should use this brilliant tool which can easily convert your ost into pst.
ericcarter
Re: OST to PST converter
« Reply #1 on: 28. December 2018., 07:00:50 »
If the discussion about the OST to PST converter then SysData OST to PST conversion software stands at the top of all. This software uses advanced technology to repair highly corrupted OST file and convert entire OST mailbox data like emails, calendars, contacts, notes, tasks, journals & other data. The tool provides multiple option to export OST data to PST, EML, EMLX, MSG, HTML, MBOX, vCard and vCal file format. With this tool, you can import offline OST file to Office 365 & Live Exchange server. The software has more features and benefits and you can know about by downloading the tool at FREE of cost.
graceponting
« Reply #2 on: 31. December 2018., 08:47:22 »
If you want best OST to PST Converter then I would like to suggest you top ranked PDS OST to PST Converter Software without any hassle. With the assist of this conversion software you can convert all mailbox item folders such as PST, EML, MSG, MBOX, HTML, PDF and Office 365 file format. It also Split large PST file into small PST file without any changes in file. This program setup is also intelligent to converts all emails Meta properties such as to/from/cc/ bcc/subject/date and time. It is workable with MS outlook version from 97 to 2019 including Windows version up to win 10.
Linda Harris
« Reply #3 on: 01. January 2019., 06:30:34 »
Gets an easy Exporter from OST to PST file format using OST to PST Migration Full Version? The tool provides the best and easy method by which you can smoothly export OST to PST without any trouble. The OST to PST Tool provides a very quick and efficient way out for crucial mailbox data such as emails, calendar, contacts, appointments, tasks, journals, notes, etc. from corrupted OST files.
robinji
« Reply #4 on: 08. January 2019., 11:24:43 »
I would also like to share another one convenient tool such as OST to PST converter tool from BitDataConversion. It can fast and easily convert OST files into many formats like PST, EML, MSG, vCal, vCard etc.
vikash singh
Re: OST to PST software
« Reply #5 on: 11. January 2019., 10:59:47 »
I want to suggest here third party tool such as OST to PST converter tool from Bitdataconversion. This tool I found after a long period search on the Internet, It provides me trustfully an effective solution to convert OST file into multiple formats.
thomes756
« Reply #6 on: 13. May 2019., 05:58:23 »
You Can use KDETools OST to PST Converter is the best software to export OST to PST Data. This Software to Complete Conversion of OST file into change to another Format like as- PST, MBOX, MSG, HTML, vCard, vCal, EML, EMLX, etc. This software to convert OST file and import into Office 365 and live Exchange server.
singh.umendra
« Reply #7 on: 08. June 2019., 08:49:31 »
I would like to add Bitacube OST to PST Converter tool. It has free trial which helps to evaluate software features without license purchase.
watson
« Reply #8 on: 15. July 2019., 09:26:54 »
Get secure professional Inspire OST to PST Converter software to convert OST documents to PST layout. The device effortlessly extracts OST documents from every folder and perform smooth recuperation. The device is ideal sufficient to save the exported outcomes at a user-distinct place.
Download free!
kaylajoy
« Reply #9 on: 12. August 2019., 11:22:02 »
Try the latest version of OST to PST Converter, for your file migration. The advanced version of OST to PST supports all the latest versions of windows. This software also supports the latest version of Windows XP, Vista, 2000, 2003, 2006, 2010, 2013, 2019, etc… You can try this tool.
