  • Total Topics: 10988
  • Online Today: 3013
Author Topic: OST to PST software  (Read 8350 times)
mariyajennifer
Re: OST to PST software
« Reply #10 on: 10. September 2019., 06:50:51 »
Secure convert OST to PST through converter Tool available by eSoftTools, this tool works efficiently with all file version of MS Outlook such: 2000, 2003, 2007, 2010, 2013, 2016, 2019. Some of its best features are:-
  • Offers multiple formats for OST file conversion like MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook.
  • Does not require installation of MS Outlook for Converting OST file.
  • Convert OST to Office 365.
  • Shows smart preview before conversion.
  • Convert large OST file into PST Outlook without any size limit.
  • A FREE DEMO version is available, up to 50 emails can easily be converted.
alex786
OST to PST software
« Reply #11 on: 11. September 2019., 07:55:22 »
Check out a free trial version of Shoviv OST to PST Software to know how does it work and what is its features. The demo version will also allow the users to convert first twenty-five items per folder. To import unlimited OST files into PST, EML, MSG, Office 365, and Live Exchange server, one can use a full version of Shoviv OST to PST Converter tool.
anthonyjohnson
« Reply #12 on: 12. September 2019., 06:17:39 »
OST to PST Converter is a great designed software that migrate OST data to PST format. By this tool, the users can recover and access inaccessible OST items such as emails, contacts, notes, journals, tasks, calendars, etc. in an effortless manner. The application works effectively with all editions of MS Outlook including Outlook 2003, 2007, 2010, 2013, 2016, 2019, etc.
More info visit ToolsBaer.
matthew021
« Reply #13 on: 12. September 2019., 07:12:46 »
If you are searching Convert OST file tool so I recommend to you MailsClick Convert OST file this tool has many advanced features such as Convert OST file to Other file is a reliable tool to convert corrupted or damaged OST files without any data loss. You can convert OST file to other multiple file formats like PST, EML, EMLX, MSG, MBOX, VCF, etc. This software supports all versions of MS Outlook and Windows.
Aisha Winged
« Reply #14 on: 17. September 2019., 12:04:51 »
Know how to convert OST file to in Outlook 2019, 2016, 2013, 2010, 2007, etc. Step by Step process to easily transfer OST file to PST format.
By using this best utility you can easily export or import OST data into PST mailbox in bulk. The Gael OST to PST Converter software is specially designed for those users who want to move all OST items or selective data in Outlook PST folder with attachments.
Aisha Winged
« Reply #15 on: 17. September 2019., 12:08:49 »
Akshay_M
« Reply #16 on: 02. October 2019., 18:45:06 »
Export mailbox as a PST file
Login to Outlook with the Exchange email hosting account that was used to create the OST files. And to export the OST mailboxes to PST, follow the simple procedure:
Go to Files >Open & Export and click Import & Export.
Select Export to a file; then click Next.
Select the second option—Outlook Data File (.pst)—and click Next.
Select the folder which you want to export and click Next.
Browse the location where you want to save the new PST file and choose the options regarding the duplicate items.
Akshay
Connorwalker
« Reply #17 on: 12. October 2019., 07:50:35 »
If you have damage OST file data and you think how can I convert OST to PST file so, now stop thinking just download best ToolsGround OST to PST Converter software which quickly get rid exchange OST file errors and convert them into working MS outlook inbox, outbox, sent mail, junk mails, deleted emails, journal, contact and calendar and support office 2019.
Anni braun
« Reply #18 on: 03. January 2020., 05:09:50 »
The OST to PST Converter is required when you are not able to access Outlook emails or want to move your outlook file from one system to another system.
If you have small size data files then I will recommend going with manual methods like Powershell command or Microsoft’s in-built utilities Exmerge & NewMailboxExportRequest.
But if you have a large size ost file then I would like to suggest Stellar Converter for OST. It provides 100% safe and secure OST to PST conversion results.
mariejohn
« Reply #19 on: 13. January 2020., 09:49:09 »
OST to PST Converter is the best utility to export the files without losing any information. It offers the users to export corrupted, cached, orphaned OST files to PST format. It is capable enough to split the large OST files to smaller ones and can efficiently merge all the OST data files to a single PST folder after the conversion process.
The Offline OST to PST Converter offers the user to move and convert single or multiple files at once with all the attachments embedded in it. It is an independent utility that does not require the installation of Outlook to switch the files format. A free trial version of this tool is also available that avails the users to export 25 OST files at once without any restrictions.
