  • Total Topics: 11542
  • Online Today: 1129
Author Topic: Bitacube Lotus Notes to Office 365 Migration  (Read 1976 times)
Stephen
« on: 25. August 2019., 09:44:47 »
Here is an introduction of recently developed Windows compatible Lotus Notes to Office365 Migration Tool. It has several features:-
•   Allows export Lotus Notes NSF emails, arrangements, calendars, contacts, etc. to Office365.
•   Migrate NSF data to Live Exchange Server, PST, EML, MSG, HTML, etc.
•   Select multiple files to export.
•   Use for Lotus Notes version 6.5/7.0/8.0/8.5/9.0.1 edition.
•   All Windows Operating System.
To get more familiar with Bitacube Lotus Notes to Office365 Migration Tool download the trial version available at BitaCube.
matthew021
Re: Bitacube Lotus Notes to Office 365 Migration
« Reply #1 on: 12. September 2019., 07:20:04 »
User may try to download MailsClick Convert NSF File to PST to export 8.5, 8.0, 7.0, 6.5, 6.0 & 5.0, etc. Lotus Notes version NSF files to MS Outlook 2003, 2007, 2010, 2013, 2016, 2019 Exchange Server, and Office 365. You Can convert NSF file to PST file format and PST file easily to Migrate Office 365. It helps Export NSF with entire emails, contacts, messages, journals, calendars, etc. to PST, EML, EMLX, MSG, MBOX, files format.
Akshay_M
« Reply #2 on: 01. October 2019., 17:25:48 »
Migration from Lotus Notes to Office 365
One can migrate from Lotus Notes to Office 365 or Exchange with the help of IMAP Connector. Below mentioned are the steps for Lotus Notes to Office 365 migration:
Backup NSF files
First of all, back up your NSF files. In case your migration fails and NSF files get corrupt during the migration, you can recover the mailbox data from the backups.
Create new Mailboxes for each NSF user
Now, create new mailboxes for each user who has an account in IBM Lotus Notes.
Enable IMAP TCP/IP port
You need to enable the IMAP TCP/IP port for each user account. Just follow the upcoming steps to do the same:
Open Domino Administrator in Lotus Notes Application.
Go to the Configuration tab.
Open the Server document which executes the IMAP service.
Click Ports>Internet Ports>Mail tab.
In Mail (IMAP) column, change the ‘TCP/IP port value status’ to Enabled.
Click the Save button to save the changes and close the application.
Synchronize with IMAP Connector
Finally, use IMAP connector to synchronize mailboxes between Lotus Notes and Office 365 during.
Akshay
