  • Total Topics: 11028
  • Online Today: 3055
Author Topic: Export OST to PST Outlook 2016  (Read 2365 times)
williamrhodes079
« on: 09. September 2019., 12:58:22 »
By using the OST to PST converter software all the user can simply retrieve all the OST file inner components such as emails, tasks, notes, journals, chats, tasks, and after the recovery also user can export them to multiple accessible file formats such as PST, EML, EMLX, MSG, HTML, vCard, VCF, MBOX, and Office 365. This eSoftTools  OST to PST Conversion toolsupports all version of MS Outlook OST file (including- 2016, 2013, 2010, 2007, 2003, and below version) and able to perform the conversion of OST to PST without any Outlook installation.
chloejohnson
Re: Export OST to PST Outlook 2016
« Reply #1 on: 10. September 2019., 06:32:26 »
I would like to refer an effective OST to PST converter software. This migration tool is able to migrate all OST mailbox item like contacts, calendars, inbox, outbox, zip attachments, appointment, tasks entries, journals, user created folders etc. It will work on all versions of MS Outlook.
matthew021
« Reply #2 on: 16. September 2019., 08:47:52 »
Advanced Convert OST File to PST Software which can convert OST file as well as switch OST file into PST file format. This Convert OST File to PST is a better alternative to transfer OST file then you can view OST files and convert into new PST file format. This application supports all MS Outlook version and Windows operating systems.
mariyajennifer
« Reply #3 on: 17. September 2019., 11:27:26 »
If your OST file is damaged and unable to access the data, convert OST to PST and restore the data. Use eSoftTools OST to PST converter tool this tool is free to download from the official website and simple to use. This tool auto-detects the location of corrupted OST file and converts them into the different formats like Office 365, MBOX, CSV, EML, MSG, and vCard, HTML, PST Outlook. Before the conversion of file this tool shows the smart preview to the user to check the conversion format. It smoothly supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and installation of MS Outlook is not required for the conversion. A FREE DEMO version is available to the entire user, easily 25 emails can be converted into each format by this demo version.
matthew021
« Reply #4 on: 18. September 2019., 08:01:57 »
The highly suggested and most helpful tool to convert OST file into PST file is MailsClick Convert OST file to PST Software. It is the tool which is approved by all users because of its characteristics like recover corrupted OST files, gives a smart preview of OST files, and many more. There is also a feature which enables the user to convert their files in other file formats as well such as MSG, MBOX, EML, EMLX, and VCF. This Application Supports MS Outlook 2003, 2007, 2010, 2013, 2016.
Adelinewalker
« Reply #5 on: 18. October 2019., 06:07:16 »
If you have damage OST file data and you think how can I convert OST to PST file so, now stop thinking just download best ToolsGround OST to PST converter software which quickly get rid exchange OST file errors and convert them into working MS outlook inbox, outbox, sent mail, junk mails, deleted emails, journal, contact and calendar and support office 2019.
Akshay_M
« Reply #6 on: 23. October 2019., 17:25:55 »
You can Use ‘Archiving’ to save OST emails to PST
When you enable email archiving, Outlook emails from OST file are saved to a separate PST file. Also, it helps in keeping the size of the mailbox at an optimum level by saving the older mailbox items in the archive folder. Follow the simple steps to create a mailbox archive and save it to the desired location:
Launch the Outlook application, go to File, and click Options.
Go to Advanced and click Auto Archive Settings.
Now select the number of days in which you want to run auto archiving. Select the folder to save the archived file; also, provide the archiving options and finally click OK.
With this, mailbox items from your OST file will be saved to the PST file as per your archiving settings.
Akshay
