  • Total Topics: 11617
  • Online Today: 1311
Author Topic: PROFILE LOCATION ERROR.  (Read 3253 times)
« on: 18. April 2020., 14:21:43 »
Is There A Limit For The Number Of Characters That Can Be Entered In The Profile Location Input Field ?
I Tried To Change It Several Times, But It Gave Me Always This Error.
AN ERROR HAS OCCURRED
YOUR SESSION TIMED OUT WHILE POSTING. PLEASE GO BACK AND TRY AGAIN
Thank You.
Re: PROFILE LOCATION ERROR.
« Reply #1 on: 03. May 2020., 20:24:03 »
Hello A. and so sorry for the little bit late reply... I'm to busy on a new job in real life - started before few Weeks.
Regarding mentioned problem, We don't settled any limitations but maybe they are predefined by developers... however, We could test this with easy... simply send me desired text via Private Message and info where you want to place it... I'll try do that for you through Administrator's panel. ;)
Best Regards,
« Reply #2 on: 04. May 2020., 00:12:36 »
No Problem - The Changes Were Minimal.
Thank You, Anyway.
« Reply #3 on: 28. July 2020., 03:56:42 »
It Was An OPERA Browser Problem ( ? ) - By Using FF I Finally Managed To Change My Profile.
Thank You.
« Reply #4 on: 01. August 2020., 16:42:10 »
Great, thanks for the heads-up. :) :thumbsup:
Our Team will test browsing with Opera during a next few Weeks...
cya around SCforum,
« Reply #5 on: 02. August 2020., 01:49:50 »
Reminder,
Do Not Forget, I Am Still Using Old Software, And Because Of That I Am Also Stuck In The Past, Both In Terms Of Browsers And In Terms Of Browser Extensions.
A - I Am Still Using An Old OS ( XP ), And, Because Of That,
B - I Can Not Use The Most Recent Version Of OPERA, And, Because Of That,
C - I Can Not Use The Most Recent Versions Of Some Browser Extensions, As Well.
I Am Still Using Old OPERA 36.0.2130.80.
Thank You.
« Reply #6 on: 05. August 2020., 23:49:43 »
Yes, you have a right... our test with (updated) browsers shows that everything is Ok. :thumbsup:
cya around SCforum.
