  • Total Topics: 15521
  • Online Today: 719
Author Topic: Fix all OST corruptions with EdbMails OST to PST tool  (Read 7432 times)
marielia
If you have an orphaned or corrupted OST file then EdbMails OST Recovery tool that Convert OST file to PST is exactly what you need. Retrieve all OST contents including attachments, all email properties like cc, bcc, to/from address with just a few click using EdbMails.
Some of the reasons for OST corruption can be:
Network issues leading to synchronisation errors
System failure
Abrupt termination of Outlook
Virus or other such malicious infection
Feature of the OST Recovery tool from EdbMails include:
  • Repair corrupted OST file and convert it to PST.
  • Maintains the Folder structure intact.
  • All the data such as inbox items, sent items, contacts etc will be recovered.
  • No limitation to the size of OST file that can be recovered.
  • OST viewer to preview all OST data.
  • Free version of the tool to test out all its features and export upto 30 items per mailbox/folder.
to know more: OST to PST
sonharry
Re: Fix all OST corruptions with EdbMails OST to PST tool
« Reply #1 on: 09. June 2020., 08:10:36 »
Stella Data Recovery gives you OST to office 365 recovery tool that easily recover damage OST file data and convert OST to PST with multiple format as:- EML, MSG, HTML, MBOX and support live exchange server and office 365. This Stella OST to office 365 software easily recover and fix all OST file corruptions and then allows to save OST file to PST without data loss
Read more:- https://free-unlimited-ost-to-pst-converter.blogspot.com/
RuskinF
« Reply #2 on: 24. June 2020., 12:53:49 »
Open SCANPST.EXE.
Select Browse to select the Outlook Data File (.pst) you want to scan. If you need help locating your Outlook Data File, see Locating the Outlook Data Files.
Note: By default, a new log file is created during the scan. You can choose Options and opt not to have a log created, or you can have the results appended to an existing log file.
Choose Start to begin the scan.
If the scan finds errors, choose Repair to start the process to fix them.
Shows results of scanned Outlook .pst data file using the Microsoft Inbox Repair tool, SCANPST.EXE
Note: The scan creates a backup file during the repair process. To change the default name or location of this backup file, in the Enter name of backup file box, enter a new name, or choose Browse to select the file you want to use. You may need to run the tool several times in order to repair your Outlook Data File. In some cases, items may not be recovered if they were permanently deleted or corrupted beyond repair.
When the repair is complete, start Outlook with the profile associated with the Outlook Data File you just repaired.
mariejohn
« Reply #3 on: 08. June 2021., 09:48:33 »
Scan the corrupted, damaged, orphaned OST emails with the best solution offered by ZOOK OST to PST Converter. It is the best solution that offers the hassle-free platform to export the files format. Users can export the emails in the batch mode with all the data items attached with it. It maintains the folders hierarchy. It preserves all the email data and RTF formatting of the emails intact even after the conversion process.
OST to Outlook Converter is supportable with all the MS Outlook editions such as Outlook 2019, 2016, 2013, etc. It does not require the installation of any external utility to export the files format. A FREE DEMO VERSION for the same is also available to test the working efficiency of this tool.
Read more details at:-  Migrate OST to PST
