  • Total Topics: 16748
  • Online today: 2458
Guests: 2459
Total: 2460
Author Topic: LEGACY REQUESTS - MSDOS6.20 OS.  (Read 2848 times)
A41202813GMAIL
  • XPOCALYPSE FOREVER !
« on: 16. September 2020., 04:51:31 »
Sorry, Again,
X - Brand New MSDOS6.20 Operating System Installation
A - The Complete ( X ) Contains Dozens Of Files, But,
B - The Most Basic ( X ) Contains Only 3 Files - IO.SYS, MSDOS.SYS And COMMAND.COM, In This Very Specific Order ( I Have These 3 Files ),
C - Newly Formatted HDD.
Without Having A Previous ( X ) Already Installed, Is There Any Software That Can Make A Special "Copy" Of ( B ) Into ( C ), Allowing ( X ) To Be Bootable From There ?
Thank You.
Re: LEGACY REQUESTS - MSDOS6.20 OS.
« Reply #1 on: 17. September 2020., 04:25:01 »
From what I could find, you'll need format.com at the very least, perhaps with a boot DOS floppy in order to format the partition as DOS booteable and then transfer the basic files over.
A41202813GMAIL
« Reply #2 on: 17. September 2020., 11:34:26 »
The File S(Y)S.COM Does Everything I Need, But Demands These 2 Conditions :
A - ( Y ) Must Be Of The Version Of The Intended OS ( Which Is Not A Problem, Because I Have All The Files Of That OS ),
B - ( Y ) Must Be Already Running Under That Specific OS ( Which Is My Only Problem, Because I Need To Install The OS From Scratch And I Do Not Have That OS Already Running ).
Thank You.
A41202813GMAIL
LEGACY REQUESTS - SOFTWARE CONVERTERS.
« Reply #3 on: 13. November 2021., 11:32:36 »
Hello,
X - Disk Image File Types With Bootable Information Included,
A - Currently The Most Common ( X ) Is .ISO,
B - .IMA, .IMG And .IMZ Were Also Former DOS Legacy ( X ).
Is There Any Free Software Capable Of Converting Any ( B ) Into ( A ) ?
Thank You.
