  • Total Topics: 16768
  • Online today: 12857
  • Online ever: 167845
  • (01. June 2025., 05:25:03)
Guests: 12769
Total: 12770
Author Topic: Outlook PST Splitter - Archive Outlook and split PST files automatically  (Read 4651 times)
tomcurran7751
In Manual method, there are some limitation which makes it worst so problem of large pst files is really serious because you may lose your important data if you are unable to find the right solution.
However, there are many third-party software to split pst file which are large but selecting the perfect one is quite difficult and if you want any recommendation then i would highly recommend you to use this PST splitter software which can easily split your large and over large pst files into small parts of pst files. This software generate log report of entire this process to assist you in verifying the total number of items.
It comes with so many advanced and well developed features to add more accuracy and efficiency in this software which provides lots of option to reliably split pst data. This software can support all version of MS Outlook such as 2019, 2016, 2013, 2010, 2007 & 2003 and compatible to all latest windows such as 10, 8.1, 8, 7. This software is 100% safe and secure which ensure the data during process and maintain the original formatting.
Visit here:- https://www.softmagnat.com/split-pst.html
angus20
 The PST split Tool helps user to split large-sized PST files located anywhere on the system into small-sized PST files. This tool helps user to protect an Outlook PST file from corruption which frequently occurs due to oversized PST files. It gives options of splitting PST by Date, Size, Mail id, Folder etc. This software can split Outlook PST files without changing the structure. To know more about this tool, visit here: https://www.datarepairtools.com/split-pst-file.html
davidgodfin
A free Outlook Freeware PST splitter https://www.outlookfreeware.com/en/products/all/OutlookSplitPST allows you to split as many files and as many times as you want.
Discover fantastic additional versions with the advanced version:
  • Supports all PST formats, modern Unicode and outdated ANSI.
  • Preserves original data and folder hierarchy.
  • Splits Outlook PST file into smaller parts according to specified parameters.
  • Creates new smaller PST files or appends data to existing ones.
  • Attaches or detaches split data files to/from Outlook during the splitting process.
  • Skips the Deleted Items folder if necessary.
  • Splits PST created within a specified time period.
  • Provides command line and batch processing support in the Professional version of the tool.
  • Divides PST files directly within Outlook or from a standalone application without the need to launch Outlook
