  • Total Topics: 15520
  • Online Today: 715
Author Topic: Recover Exchange Server 2016  (Read 3595 times)
AlbertTaylor
« on: 02. June 2021., 06:54:57 »
Exchange server monitoring is essential for ensuring that the server runs smoothly at all times. However, no matter how diligently you monitor Exchange, you may encounter a circumstance where the Exchange server completely fails to boot at some point. It can occur as a result of faulty hardware or defective software.
If it's due to a hardware failure, you can replace it and restart the server. If the damage gets caused by corrupt software or an operating system, you can recover Exchange Server 2016 and restore the mailbox database by using the setup /m: RecoverServer switch. If the Setup m RecoverServer fails to restore the mailboxes and database to the new server, you can use Exchange Recovery software like the Shoviv Exchange Recovery tool to restore the mailboxes and database.
Shoviv Exchange Recovery Manager is a strong Exchange data recovery solution. It allows you to recover entire mailboxes or single items from corrupted .edb files in a matter of seconds. Allows you to recover and restore EDB files that are no longer available to the given location. There's also a feature called "Incremental Export/Backup in PST files," which is a more advanced feature. The tool-free demo version allows you to process the first 50 items/folder.
For more info - Recover Exchange Server
lemidezcai77
Re: Recover Exchange Server 2016
« Reply #1 on: 17. October 2021., 17:05:21 »
If any EDB client is unable to open an EDB file in Outlook, then Softaken EDB to PST Converter Software should be downloaded. This application can restore all damaged EDB mailbox objects with meta attributes and works with all versions of MS Outlook. It also recovers emails, documents, journals, appointments, attachments, deleted files, chats, notes, tasks, etc without any error. Now you may get a free demo of everything that is offered. Read more :-  https://www.softakensoftware.com/edb-to-pst-converter.html
