You may need to restore Exchange edb file in a variety of situations. One of them is hardware failure. Don't worry if something goes wrong; Exchange has a Data Protection Manager that takes care of data backup and recovery. You may recover a mailbox from an EDB file with this application.
Eseutil.exe is a Microsoft Corporation command-line tool that gets used to recover Exchange EDB files. Microsoft Exchange is a platform that allows you to connect several Outlook Client accounts in one place. All of the data in Exchange Server's mailboxes get saved in the EDB file format. However, corruption in EDB files can result in huge losses for the server user.
Eseutil is only for technical people; novice people will find it difficult to use. The technique is extensive and time-consuming because it comprises five independent steps. If you don't have a backup of the Exchange Server, you shouldn't use Eseutil. Because you will not able to execute these commands correctly, then data loss is a possibility.
The EDB recovery is effective if the EDB files are mounted successfully. Otherwise, the database may suffer from serious corruption. In this case, we recommend using the most reliable professional Exchange EDB to PST Converter, which Exchanges perfectly restore Exchange edb file.
Shoviv Exchange EDB Recovery Tool is capable of recovering damaged and corrupted EDB files. This software has a lot of advantages, and it expertly recovers Exchange Server's private and public folders.
It expertly recovers EDB Items from Exchange mailboxes that have been deleted, corrupted, or dismounted. The tool enable to load of several EDB files into the software at once for processing. It does a quick scan and recovery for Exchange EDB files, regardless of their size. This software works with all versions of Exchange Server and Microsoft Outlook. There is also a free demo version of the software available to evaluate its functionality. The first 50 items in each folder are free to recover, convert, and save using the tool demo version.
For more info visit -
https://www.shoviv.com/exchange-recovery.html
