  • Total Topics: 16999
  • Online today: 23577
Guests: 20821
Total: 20821
Author Topic: Known Vulnerabilities in Mozilla Products  (Read 5337 times)
« on: 30. May 2007., 23:11:38 »
This page will contain a list of the security vulnerabilities known to affect particular versions of Mozilla products and instructions on what users can do to protect themselves. The list will be added to when new security problems are found.
Please read Mozilla.org's security bug policy for information on how we handle these bugs. If you have found a security problem which is not on this list and has not been filed as a public Bugzilla bug, or if you find errors or inconsistencies in this list, please send us information.
This is not meant as an exhaustive list of all security-related bugs. To find technical discussions of security-related bugs, visit Bugzilla. This page lists security vulnerabilities with direct impact on users. All of these vulnerabilities have been fixed prior to the most recent release.
Firefox vulnerabilities
Thunderbird vulnerabilities
SeaMonkey vulnerabilities
Mozilla Suite vulnerabilities
Older vulnerabilities
Impact key:
Critical: Vulnerability can be used to run attacker code and install software, requiring no user interaction beyond normal browsing.
High: Vulnerability can be used to gather sensitive data from sites in other windows or inject data or code into those sites, requiring no more than normal browsing actions.
Moderate: Vulnerabilities that would otherwise be High or Critical except they only work in uncommon non-default configurations or require the user to perform complicated and/or unlikely steps.
Low: Minor security vulnerabilities such as Denial of Service attacks, minor data leaks, or spoofs. (Undetectable spoofs of SSL indicia would have "High" impact because those are generally used to steal sensitive data intended for other sites.)
Firefox 2
Fixed in Firefox 2.0.0.3
MFSA 2007-11 FTP PASV port-scanning
Fixed in Firefox 2.0.0.2
MFSA 2007-09 Privilege escalation by setting img.src to javascript: URI
MFSA 2007-08 onUnload + document.write() memory corruption
MFSA 2007-07 Embedded nulls in location.hostname confuse same-domain checks
MFSA 2007-06 Mozilla Network Security Services (NSS) SSLv2 buffer overflow
MFSA 2007-05 XSS and local file access by opening blocked popups
MFSA 2007-04 Spoofing using custom cursor and CSS3 hotspot
MFSA 2007-03 Information disclosure through cache collisions
MFSA 2007-02 Improvements to help protect against Cross-Site Scripting attacks
MFSA 2007-01 Crashes with evidence of memory corruption (rv:1.8.0.10/1.8.1.2)
Fixed in Firefox 2.0.0.1
MFSA 2006-76 XSS using outer window's Function object
MFSA 2006-75 RSS Feed-preview referrer leak
MFSA 2006-73 Mozilla SVG Processing Remote Code Execution
MFSA 2006-72 XSS by setting img.src to javascript: URI
MFSA 2006-71 LiveConnect crash finalizing JS objects
MFSA 2006-70 Privilege escalation using watch point
MFSA 2006-69 CSS cursor image buffer overflow (Windows only)
MFSA 2006-68 Crashes with evidence of memory corruption (rv:1.8.0.9/1.8.1.1)
Firefox 1.5
Fixed in Firefox 1.5.0.11
Fixed in Firefox 1.5.0.10
Fixed in Firefox 1.5.0.9
Fixed in Firefox 1.5.0.8
MFSA 2006-67 Running Script can be recompiled
MFSA 2006-66 RSA signature forgery (variant)
MFSA 2006-65 Crashes with evidence of memory corruption (rv:1.8.0.8)
Fixed in Firefox 1.5.0.7
MFSA 2006-64 Crashes with evidence of memory corruption (rv:1.8.0.7)
MFSA 2006-62 Popup-blocker cross-site scripting (XSS)
MFSA 2006-61 Frame spoofing using document.open()
MFSA 2006-60 RSA Signature Forgery
MFSA 2006-59 Concurrency-related vulnerability
MFSA 2006-58 Auto-Update compromise through DNS and SSL spoofing
MFSA 2006-57 JavaScript Regular Expression Heap Corruption
Fixed in Firefox 1.5.0.5
MFSA 2006-56 chrome: scheme loading remote content
MFSA 2006-55 Crashes with evidence of memory corruption (rv:1.8.0.5)
MFSA 2006-54 XSS with XPCNativeWrapper(window).Function(...)
MFSA 2006-53 UniversalBrowserRead privilege escalation
MFSA 2006-52 PAC privilege escalation using Function.prototype.call
MFSA 2006-51 Privilege escalation using named-functions and redefined "new Object()"
MFSA 2006-50 JavaScript engine vulnerabilities
MFSA 2006-48 JavaScript new Function race condition
MFSA 2006-47 Native DOM methods can be hijacked across domains
MFSA 2006-46 Memory corruption with simultaneous events
MFSA 2006-45 Javascript navigator Object Vulnerability
MFSA 2006-44 Code execution through deleted frame reference
Fixed in Firefox 1.5.0.4
MFSA 2006-43 Privilege escalation using addSelectionListener
MFSA 2006-42 Web site XSS using BOM on UTF-8 pages
MFSA 2006-41 File stealing by changing input type (variant)
MFSA 2006-39 "View Image" local resource linking (Windows)
MFSA 2006-38 Buffer overflow in crypto.signText()
MFSA 2006-37 Remote compromise via content-defined setter on object prototypes
MFSA 2006-36 PLUGINSPAGE privileged JavaScript execution 2
MFSA 2006-35 Privilege escalation through XUL persist
MFSA 2006-34 XSS viewing javascript: frames or images from context menu
MFSA 2006-33 HTTP response smuggling
MFSA 2006-32 Fixes for crashes with potential memory corruption (rv:1.8.0.4)
MFSA 2006-31 EvalInSandbox escape (Proxy Autoconfig, Greasemonkey)
Fixed in Firefox 1.5.0.3
MFSA 2006-30 Deleted object reference when designMode="on"
Fixed in Firefox 1.5.0.2
MFSA 2006-29 Spoofing with translucent windows
MFSA 2006-28 Security check of js_ValueToFunctionObject() can be circumvented
MFSA 2006-27 Table Rebuilding Code Execution Vulnerability
MFSA 2006-25 Privilege escalation through Print Preview
MFSA 2006-24 Privilege escalation using crypto.generateCRMFRequest
MFSA 2006-23 File stealing by changing input type
MFSA 2006-22 CSS Letter-Spacing Heap Overflow Vulnerability
MFSA 2006-20 Crashes with evidence of memory corruption (rv:1.8.0.2)
MFSA 2006-08 "AnyName" entrainment and access control hazard
MFSA 2006-07 Read beyond buffer while parsing XML
MFSA 2006-06 Integer overflows in E4X, SVG and Canvas
MFSA 2006-05 Localstore.rdf XML injection through XULDocument.persist()
MFSA 2006-04 Memory corruption via QueryInterface on Location, Navigator objects
MFSA 2006-03 Long document title causes startup denial of Service
MFSA 2006-02 Changing postion:relative to static corrupts memory
MFSA 2006-01 JavaScript garbage-collection hazards
MFSA 2006-19 Cross-site scripting using .valueOf.call()
MFSA 2006-18 Mozilla Firefox Tag Order Vulnerability
MFSA 2006-17 cross-site scripting through window.controllers
MFSA 2006-16 Accessing XBL compilation scope via valueOf.call()
MFSA 2006-15 Privilege escalation using a JavaScript function's cloned parent
MFSA 2006-14 Privilege escalation via XBL.method.eval
MFSA 2006-13 Downloading executables with "Save Image As..."
MFSA 2006-12 Secure-site spoof (requires security warning dialog)
MFSA 2006-11 Crashes with evidence of memory corruption (rv:1.8)
MFSA 2006-10 JavaScript garbage-collection hazard audit
MFSA 2006-09 Cross-site JavaScript injection using event handlers
Firefox 1.0
Firefox 1.0 is no longer supported and the last update, Firefox 1.0.8, is affected by several vulnerabilities fixed in newer versions of the program. All users are urged to upgrade to the newest version of Firefox.
Fixed in Firefox 1.0.8
Fixed in Firefox 1.0.7
MFSA 2005-59 Command-line handling on Linux allows shell execution
MFSA 2005-58 Firefox 1.0.7 / Mozilla Suite 1.7.12 Vulnerability Fixes
MFSA 2005-57 IDN heap overrun using soft-hyphens
Fixed in Firefox 1.0.5/1.0.6
MFSA 2005-56 Code execution through shared function objects
MFSA 2005-55 XHTML node spoofing
MFSA 2005-54 Javascript prompt origin spoofing
MFSA 2005-53 Standalone applications can run arbitrary code through the browser
MFSA 2005-52 Same origin violation: frame calling top.focus()
MFSA 2005-51 The return of frame-injection spoofing
MFSA 2005-50 Exploitable crash in InstallVersion.compareTo()
MFSA 2005-49 Script injection from Firefox sidebar panel using data:
MFSA 2005-48 Same-origin violation with InstallTrigger callback
MFSA 2005-47 Code execution via "Set as Wallpaper"
MFSA 2005-46 XBL scripts ran even when Javascript disabled
MFSA 2005-45 Content-generated event vulnerabilities
Fixed in Firefox 1.0.4
MFSA 2005-44 Privilege escalation via non-DOM property overrides
MFSA 2005-43 "Wrapped" javascript: urls bypass security checks
MFSA 2005-42 Code execution via javascript: IconURL
Fixed in Firefox 1.0.3
MFSA 2005-33 Javascript "lambda" replace exposes memory contents
MFSA 2005-34 javascript: PLUGINSPAGE code execution
MFSA 2005-35 Showing blocked javascript: popup uses wrong privilege context
MFSA 2005-36 Cross-site scripting through global scope pollution
MFSA 2005-37 Code execution through javascript: favicons
MFSA 2005-38 Search plugin cross-site scripting
MFSA 2005-39 Arbitrary code execution from Firefox sidebar panel II
MFSA 2005-40 Missing Install object instance checks
MFSA 2005-41 Privilege escalation via DOM property overrides
Fixed in Firefox 1.0.2
MFSA 2005-32 Drag and drop loading of privileged XUL
MFSA 2005-31 Arbitrary code execution from Firefox sidebar panel
MFSA 2005-30 GIF heap overflow parsing Netscape extension 2
Fixed in Firefox 1.0.1
MFSA 2005-29 Internationalized Domain Name (IDN) homograph spoofing
MFSA 2005-28 Unsafe /tmp/plugtmp directory exploitable to erase user's files
MFSA 2005-27 Plugins can be used to load privileged content
MFSA 2005-26 Cross-site scripting by dropping javascript: link on tab
MFSA 2005-25 Image drag and drop executable spoofing
MFSA 2005-24 HTTP auth prompt tab spoofing
MFSA 2005-23 Download dialog source spoofing
MFSA 2005-22 Download dialog spoofing using Content-Disposition header
MFSA 2005-21 Overwrite arbitrary files downloading .lnk twice
MFSA 2005-20 XSLT can include stylesheets from arbitrary hosts
MFSA 2005-19 Autocomplete data leak
MFSA 2005-18 Memory overwrite in string library
MFSA 2005-17 Install source spoofing with user:pass@host
MFSA 2005-16 Spoofing download and security dialogs with overlapping windows
MFSA 2005-15 Heap overflow possible in UTF8 to Unicode conversion
MFSA 2005-14 SSL "secure site" indicator spoofing
MFSA 2005-13 Window Injection Spoofing
MFSA 2005-12 javascript: Livefeed bookmarks can steal private data
MFSA 2005-09 Browser responds to proxy auth request from non-proxy ssl server
MFSA 2005-08 Synthetic middle-click event can steal clipboard contents
MFSA 2005-07 Script-generated event can download content without prompting
MFSA 2005-05 Input stealing from other tabs
MFSA 2005-04 Secure site lock can be spoofed using view-source:
MFSA 2005-03 Secure site lock can be spoofed by a binary download
MFSA 2005-02 Opened attachments are temporarily saved world-readable
MFSA 2005-01 Link opened in new tab can load local file
