  • Latest: Nikita
  • Total Topics: 16635
  • Online today: 2702
Users: 5
Guests: 2639
Total: 2644
Author Topic: Recover your /home data with an Ubuntu CD USB Boot Disk from a ZFS partition  (Read 4118 times)
I was lucky so I better write it down.
Linux sucks. I'm using Ubuntu 20.04 and it wouldn't boot any longer. Recovery console was too fast to catch so I booted with an installation USB.
Then the question is: how to mount my old hard disk and copy my /home/data to safety!
sudo su -
mkdir /home/myhome
zpool status
sudo zpool import rpool rpoolssd
--> you have to rename rpool to avoid conflicts, or so I think!
zpool status
Code: [Select]
Which gives for me:
pool: bpool
 state: ONLINE
  scan: scrub repaired 0B in 0 days 00:00:01 with 0 errors on Sat Aug  7 22:24:03 2021
config:
NAME                                    STATE     READ WRITE CKSUM
bpool                                   ONLINE       0     0     0
  c2124c91-6e47-ff42-85e7-3c1199be6f2b  ONLINE       0     0     0
errors: No known data errors
  pool: rpoolssd
 state: ONLINE
  scan: scrub repaired 0B in 0 days 01:52:25 with 0 errors on Sun Aug  8 00:16:27 2021
config:
rpoolssd                                ONLINE       0     0     0
  c6576671-0ca6-f14a-9633-088e41e229d4  ONLINE       0     0     0
zfs list -ro canmount,mountpoint,mounted,name rpoolssd
--> that gives, for me:
Code: [Select]
      on  /home/myhome                     no  rpoolssd/USERDATA/myhome_a3k59c
      on  /root                          no  rpoolssd/USERDATA/root_a3k59c
zfs set mountpoint=legacy rpoolssd
mount -t zfs rpoolssd/USERDATA/myhome_a3k59c /home/myhome
if you make yourself root (sudo su -), you have full rights to all the files. You can remove what you don't need, then make a backup of your freshly mounted zfs /home/myhome mountpoint as follows:
cd /home
Code: [Select]
tar -cpzf /media/ubuntu/hdd11/myhome.tar.gz --exclude=*tmp --exclude=myhome.tar.gz --exclude=.cache --exclude=.debug --exclude=.dbus --exclude=.gvfs --exclude=.local/share/gvfs-metadata --exclude=.local/share/Trash --exclude=.recently-used --exclude=.thumbnails --exclude=.xsession-errors --exclude=.Trash --exclude=.steam --exclude=Downloads --exclude=GitHub --exclude=Public --exclude=Steam --exclude=Templates --exclude="VirtualBox VMs" --warning=no-file-changed ./myhome/
With /media/ubuntu/hdd11 a disk I mounted with gnome's disks app.
Hoa Dao
Your article is very good and useful, thank you for sharing, mig8 hopes that next time you will have more good articles to send to all readers.
