When choosing a cooking spoon, the three most common types are wood, metal, and plastic. Each material has its pros and cons, but if you visit the kitchens of professional and casual chefs around the world, the one you're most likely to see is the wooden spatula. Why do more and more people like to cook with wooden spatulas?
wooden cutlery
1. Wooden spatula will not scratch kitchen utensils
Metal spoons are more likely to scratch the bottom and sides of pots and pans. This is very problematic with non-stick surfaces, as the food will start to stick to the bottom, making cooking on the pan and cleaning up more difficult afterward. You may end up just throwing the pot or pan out. However, the disposable wooden spatula is naturally soft and will not scratch the surface of non-stick pans or damage the surface of cast iron/stainless steel pans, ensuring long hours of enjoyable cooking.
2, wooden spatula is very strong
Anyone who's been in the kitchen knows that sometimes one of the most important ingredients in any dish is a little elbow grease. A good stir, flip, or scrape can give everything the attention it needs to balance heat and flavor, especially when it comes to sauces. The wooden spatula gives you a firm grip to make mixing easier and more efficient, and you don't have to worry about the handle breaking. It also gives you a reliable tool for scraping things off the sides and bottom of the pan.
3. Wooden spatula does not conduct heat
Metal spoons can get very hot when introduced to high temperatures. The plastic spoon will start to melt. The disposable wooden spatula doesn't conduct heat, so you can stir to your heart's content without worrying about the handle getting hot. Plus, if you happen to leave the spoon in the pan for a short period of time, you don't have to worry about it getting hot or melting.
4. Wooden spatula won't react badly to your food
Disposable wooden spatula is non-reactive, which means the wood doesn't react adversely with the acids in some foods and doesn't leave a nasty metallic taste, as metal spoons often do. Over time, the edges of plastic spoons will start to break down. This can result in little unappetizing pieces of plastic being left in the pan. To ensure the purity of any recipe, there really is no substitute like a wooden spatula or other wooden utensils.
5. Wooden spatula will not change the cooking temperature
Believe it or not, some spoons actually absorb heat, changing the temperature of the food you're cooking. This can be very problematic when you are cooking something that requires a precise temperature. It messes up the consistency, flavor and in some cases completely ruins the dish. The disposable wooden spatula is insulating, so foods or recipes that might be sensitive to sudden changes in temperature won't be affected when you use them.
6. Wooden spatula will not leach harmful chemicals
Bacteria and germs are not big fans of wood. In fact, due to the natural germicidal properties of wooden spatulas, the disposable wooden spatula is much safer than any other spoon. You still need to make sure your spoons are all FDA compliant and don't contain any harmful chemicals that could leach into your food. Buy a properly made wooden spatula and maintain it properly, and you won't have to worry about anything bad being introduced to your food or your family.
7. Wooden spatula feels great
Nothing beats the firm, sturdy and smooth grip of a wooden spatula. The handle feels just right in your hand. And the more you use it, the better it feels. It's as if it's made for your hand. This comfortable grip makes stirring easier and more efficient, enriching your cooking experience.
8. Wooden spatula looks beautiful
Classic, gorgeous and elegant, a kitchen filled with wooden spatula always makes a good impression. While adding decoration might not be the most important aspect of a disposable wooden spatula, it certainly doesn't hurt to cook it in a certain style. Sometimes a proper set of wooden spatulas separates a good kitchen from a good one.
9. Wooden spatula is more environmentally friendly
Wood is a naturally renewable resource, so if you want to cook in the most environmentally friendly way, a disposable wooden spatula should be your tool of choice. Also, when you purchase a disposable wooden spatula that is made without the use of harmful chemicals, you eliminate the possibility of those chemicals leaking into the environment and your home.
