  • Total Topics: 16978
  • Online today: 137655
Guests: 133948
Total: 133950
Author Topic: DVD-Cloner IV 4.20 Build 917  (Read 5804 times)
« on: 05. June 2007., 22:51:58 »
DVD-Cloner is a super easy tool to copy DVDs to DVD-R/RW. DVD-Cloner 3 makes backing up your copy-protected DVD movies simple. With your DVD burner and DVD Cloner software, you pop in the DVD you want to copy in your DVD-ROM and a blank DVD in your DVD Burner and click the button to start the DVD burning process. You can clone your DVD entirely within 2-3 hours, in the same quality as the original. The cloned DVD can be played in any compatible DVD Player. Plus, DVD Cloner 3 is one of the few DVD backup software titles that has a built-in CSS/DVD Ripper. You do not need to download a separate program like DVD43 or AnyDVD.
DVD-CLONER Features:
* Perfect 1:1 DVD Copy. Copy entire DVDs including the title, menus, subtitles, audio & languages – or just the parts you want.
* Decode CSS or DECROSS protected discs
* Create Customized Copies. Now you can select your favorite title, chapter, subtitles or audio for copying.and previewfavorite chapter.
* Supports Episodic DVDs. Choose your preferred sections without copying the whole DVD.
* Copy DVD-9 to DVD-5. Compress one DVD-9 movie onto one D5 dvd+-r/rw without noticeable quality loss.
* Copy DVD-9 to DVD-9. Copy a DVD-9 movie to an 8.5GB dual layer dvd+r/rw without any quality loss.
* Full DVD disc copy. Copy a D9/D5 Movie/data/music disc to another D9/D5 disc without compressing the movie or deleting the coping protection, and also including the title, menu and other special features.
* Split one D9 to two D5. Copy one DVD-9 movie onto two D5 dvd+-r/rw without any quality loss.
* ‘DVD Fix’ copying mode: It can recover the damaged DVDs to the greatest extent. To deal with DVDs in poor quality or with seriously damaged slices, we designed DVD Fix mode to read files to hard disc and greatly optimize the reading speed and quality. The optimized disc is readable by DVD-ROM.
* High Compatibility. Supports PAL, NTSC, DVD+-R/RW and most DVD players and burners.
* High Speed. DVD copy takes less than one hour to finish.
* Adjust the compression rate.? You can get a better video effect and less size of your DVD by this function, also can adjust the compression rate from 10% to 100%.
* Preview the movie, extras and menus.
* Multi language: Support most popular languages.
What'new in DVD-Cloner IV:
- Two newly designed interfaces: Express mode is the fool-prove way to copy DVD. It only takes one click to copy your DVD! While Expert mode is more professional and customized. It make you a DVD copy expert!
- DVD-Cloner IV is fully compatible with Windows Vista operating system. It takes the lead in supporting Windows Vista operating system
- Enhanced decoder to defeat all up-to-date DVD protection mechanisms
- Upgraded burning kernel and encoding engine
- New“DVD Fix” copying mode allow you to recover damaged DVDs
- Fixed many bugs found in DVD-Cloner III
- Bundled with FREE DVD-TO-AVI,DVD-TO-MPEG,DVD-TO-SVCD.Now one copy of DVD-Cloner means 4 great products!
Changes in DVD-Cloner IV v4.20 - 29 Apr 2007:
1.The burning engine is redesigned to make the burning more stable and dependable
2. The "FULL DVD DISC COPY" function is enhanced. Now it can remove various protections (REGION, CSS, ARCCOS,etc.) during copying.
3. Some bugs in 4.10 are corrected
Download:
http://fs03n5.sendspace.com/dl/7e61fe40278c5cf4f5dc07784803e52b/4665cc686f52eaf1/k94q7g/DVD-Cloner.4.20.917_Soft-Hard.net.rar
