  • Total Topics: 17051
  • Online today: 9346
Guests: 9228
Total: 9231
Author Topic: McAfee Desktop Firewall 8.5  (Read 115903 times)
jake2pointzero
« on: 25. April 2009., 22:37:08 »
Hi Everybody,
Can you posts some reviews, comments(bad and good) or anything regarding McAfee Desktop Firewall 8.5.
Samker:
Is it ok to combine Mcafee Desktop Firewall 8.5 with McAfee VirusScan Enterprise 8.5i & Anti-Spyware?
Thanks
DL Link : Forbiden Content, against SCforum TOS: http://scforum.info/index.php/topic,2.0.html
2. Transmitting through our site any information, data, graphics, files, text, software, or any other material that are or may be considered to be unlawful, harmful, threatening, abusive, defamatory, vulgar, pornographic, obscene, hateful, racially, or ethnically or otherwise objectionable, is prohibited.
In addition, you agree not to post any links to warez sites and sites with download possibilities from malware (viruses, trojans, worms, backdoors, etc.).
Re: McAfee Desktop Firewall 8.5
« Reply #1 on: 26. April 2009., 07:19:27 »
Hi Jake,
this is one Excellent FireWall with very simple configuration... and use them in mentioned combination with other McAfee Products.  ;)
Don't know what other SCF Members think about them, since this version is maybe outdated ( 2003. ?? ) ??
P.S.
I was remove download link since it's against SCF TOS... (as I know this program doesn't have free download version ??)
jake2pointzero
« Reply #2 on: 26. April 2009., 11:07:22 »
sorry for the DL link, it will not happen again
« Reply #3 on: 26. April 2009., 12:06:43 »
No problem my friend.  ;)
F3RL
« Reply #4 on: 02. May 2009., 09:44:23 »
Samker, I've used MDF8.5 with VSE8.5, is there a way to 'combine' two separate icons of Desktop Firewall and VirusScan? Because I got two separate icons on my task bar, want to get rid of it.
Thanks.
« Reply #5 on: 02. May 2009., 19:49:01 »
Eric, I don't think to it's possible to integrate "everything" in to one icon...
Anyway, I'm thinking to change McAfee Desktop Firewall with McAfee Host Intrusion Prevention 7 because McAfee doesn't support anymore MDF (End of Support October 31, 2007.) and MDF has been integrated in Host IPS...: http://www.mcafee.com/us/enterprise/support/customer_service/end_life.html
so probably I'll very soon provide some new info. for SCF Community...  ;)
jake2pointzero
« Reply #6 on: 03. May 2009., 00:16:30 »
samker,
If McAfee end it support on MDF 8.5, does that means the MDF is not effective in blocking or protecting my Desktop Computer from malwares, hacker and etc?
What is Host IPS?
« Reply #7 on: 03. May 2009., 08:16:52 »
I don't think that Jake...
Firewall protection mostly depend on proper configuration.  ;)
Before few minutes I was publish Patch 4 ("old", but latest one) for Mcafee Desktop Firewall: http://scforum.info/index.php/topic,2729.0.html
I'll send you Download Link via PM in the next few minutes.  ;)
What is Host IPS?
Host IPS is inheritor of MDF, and here is few info about McAFee HIPS:
McAfee Host Intrusion Prevention monitors and blocks unwanted activity and makes it easier to keep desktops safe with multiple proven methods—system firewall, signature analysis, and behavioral analysis. And you can manage it all from one centralised console. With automatic signature updates and zero-day protection, you get advanced vulnerability-shielding capabilities. Patching systems is something you will do less often and less urgently. You’ll also find it easier to comply with legal regulations. With a single agent for host intrusion prevention on your desktops, Host Intrusion Prevention is easy to deploy, easy to configure, and easy to manage.
Features
Vulnerability shielding
Automatic security content updates target specific vulnerabilities; it recognises unknown exploits and stops them from executing; security content updates do not require system reboots
Prevents buffer-overflow exploits
McAfee Host Intrusion Prevention uses a patented host intrusion technology to prevent buffer-overflow attacks, one of the most common methods of attacking desktops
Application Blocking
Control which specific applications can run—or must never run—on any given computer for an added layer of protection
Windows firewall protection
Apply different security parameters based on how your system connects to the network (wired or wireless) with a stateful firewall for Windows; quarantine noncompliant systems as they attempt to connect to the network and block system ports
Advanced application protection
McAfee Host Intrusion Prevention puts an “envelope" around an application to prevent it from communicating with other applications; this prevents applications from being leveraged in any type of attack
Connection Isolation
Block all traffic on all but selected networks; when users "forget" to turn off wireless interfaces after connecting to the corporate LAN, this feature will ensure that no unintended breaches occur
IPV6 Support
McAfee Host IPS firewall supports the "next generation" IP protocol that is an integral component of Windows Vista
Benefits
Aggressive, comprehensive protection for your desktops
Prevent intrusions, protect assets, and safeguard desktops and laptops with three layers of protection—behavioral rules, signatures analysis, and firewall protection; protect your desktop systems against unknown (zero-day) attacks; it’s easy to manage all your desktops, regardless of location, from a single centralised console.
Protect enterprise desktops worldwide
McAfee Host Intrusion Prevention is centrally managed and scalable, so that you can deploy it across your entire enterprise for complete global protection with multiple language support
Stay ahead of threats with prioritised patch management
Use the power of McAfee Host Intrusion Prevention against new vulnerabilities and exploits when they hit for more time to research, test, and deploy patches
Lower your costs and simplify management
Reduce the frequency and urgency of patching systems; with its centralised streamlined management, you will also lower system maintenance costs
Control installation of unauthorised applications
Prevent unauthorised applications (such as games) that may increase security risk or reduce employee productivity from being installed on a system
bhimsingh
« Reply #8 on: 19. June 2009., 20:26:27 »
I don't know how it work. I never use it before. it is free to use or paid?
« Reply #9 on: 20. June 2009., 21:44:02 »
This is one old, simple & excellent FW.
Of course, Paid Corporate edition.
