  • Total Topics: 17027
  • Online today: 68623
Guests: 64659
Total: 64659
Author Topic: First Windows 7 bug discovered  (Read 6725 times)
georgecloner
« on: 11. May 2009., 00:54:41 »
Microsoft releases hot fix for bug in Windows 7 Release Candidate
Microsoft is warning customers downloading the Release Candidate of its long-awaited Windows 7 operating system that its first bug has been detected, potentially causing application failures.
In a post on the firm’s Help and Support site, Microsoft said the problem affects the 32-bit (x86) English-language version of Windows 7 build 7100, which incorrectly sets access control lists (ACLs) on the root.
Advertisement
It’s unclear just how dangerous this bug could be but Microsoft has already issued a hotfix, available through Windows update.
The x64 version of Windows 7, however, seems to be unaffected.
“In the English version of Windows 7 Release Candidate (build 7100) 32-bit Ultimate, the folder that is created as the root folder of the system drive (%SystemDrive%) is missing entries in its security descriptor,” says the posting.
“One effect of this problem is that standard users such as non-administrators cannot perform all operations to subfolders that are created directly under the root. Therefore, applications that reference folders under the root may not install successfully or may not uninstall successfully. Additionally, operations or applications that reference these folders may fail.
“For example, if a folder is created under the root of the system drive from an elevated command prompt, this folder will not correctly inherit permissions from the root of the drive. Therefore, some specific operations, such as deleting the folder, will fail when they are performed from a non-elevated command prompt. Additionally, the following error message appears when the operation fails: Access is denied.”
“Furthermore, the missing security descriptor entries protect non-admin file operations directly under the root.”
{VNUNET}
georgecloner
Re: First Windows 7 bug discovered
« Reply #1 on: 11. May 2009., 01:09:24 »
This is just one major issue not just with Win7 but also with Vista. Only Win7/Vista users should know how to deal with access permissions and privileges as an "Administrator" being a "Built-in Administrator."  Both are different in control and permission.
Good luck to all Win7 Beta and Win7 RC Testers
Same problem topic: http://scforum.info/index.php/topic,2631.0.html
mashed
    • Stressed
« Reply #2 on: 11. May 2009., 19:34:12 »
at least the 64 bit version doesnt have the problem :)
