samker,can this be installed on VSE 8.5i. what benefits can we get from it.jake
samker,Will the 5.4.00 engine be available in the auto update of the VSE 8.5i thru internet? When?jake
Is the McAfee Anti-Malware Engine the same as Engine 5400? While running the Anti-Malware, it stops and tells that McAfee is already using the latest engine.
Another question: What about "Advanced Virus Remover"? I have to uninstall it many times, every day, with Malwarebytes' Anti-Malware.Thanks for helping.
Quote from: rudelay on 04. September 2009., 18:24:38Is the McAfee Anti-Malware Engine the same as Engine 5400? While running the Anti-Malware, it stops and tells that McAfee is already using the latest engine.If I understand you correctly this isn't same Engine, 5400 is still in BETA stage. I use them, but McAfee generally don't recommend using it until final version.
