  • Total Topics: 16999
  • Online today: 23577
Guests: 20443
Total: 20443
Author Topic: PC always asked for BIOS setup  (Read 9311 times)
jake2pointzero
« on: 15. June 2009., 20:28:33 »
Fellow SCForum,
I had a problem on my computer. The problem is, everytime i turned on my PC it always asked for a BIOS setup setting. I already change the internal battery to a new one but still it asked for a BIOS setting. What seems to be the problem, need your help.
Thank you in advance.
jake
georgecloner
Re: PC always asked for BIOS setup
« Reply #1 on: 16. June 2009., 05:28:56 »
Hi Jake!
Have the same problem with my old rig with an ASUS mobo, BIOS frequently resets and posts an error message "Overclocking Fail!" which I do not usually do -- Overclocking.  Are you also running with an ASUS mobo? Because this is a common problem with ASUS nowadays which it detects wrong frequencies or high voltages causing BIOS resets.
Battery is no problem, try two things: (1) clean up your PC inside and out from dusts, incl Power Supply, (2) try replacing your PSU (power output inconsistency from power supply may possibly reset your BIOS).
GC
jake2pointzero
« Reply #2 on: 16. June 2009., 12:33:34 »
Georgecloner,
Yes i'm using a ASUS Mobo. I will try your advice and give you update.
thanks,
jake
guardian63
« Reply #3 on: 21. June 2009., 09:16:40 »
Try to update your BIOS firmware
sakthivel
« Reply #4 on: 24. June 2009., 18:15:23 »
whenever i turn on my computer it asks BIOS setup.please provide solution for me?
stevebri
« Reply #5 on: 30. June 2009., 19:38:17 »
Check to see if the bios battery needs to be replaced.
heboman
« Reply #6 on: 15. October 2009., 18:42:58 »
Make sure that you do not have a virus I had a virus that set a password to the bios ... see if you have the same status without the HD connected and after a bios reset
if the problem is there update the bios
madchip
« Reply #7 on: 13. March 2010., 16:11:22 »
Maybe battery need to be changed.
Try to change setting in manual in the bios for cpu
manual2100
« Reply #8 on: 12. October 2010., 11:33:47 »
reset the bios and if it still fails change the battery
krrjhn
« Reply #9 on: 24. January 2011., 07:45:33 »
Is it works ????
