  • Total Topics: 16528
  • Online today: 3114
Guests: 3100
Total: 3102
Author Topic: ROGUE - Smart Defender Pro (help to clean, fix, delete, remove, resolve...)  (Read 3952 times)
MikeD
There's a nasty new rogue going around called Smart Defender Pro. A number of good free tools will remove it, including SUPERAntiSpyware.
SUPERAntiSpyware has updated its definitions to detect and remove all traces of this rogue.
Download SUPERAntiSpyware from www.superantispyware.com.
Run the install.exe file.
Select “Scan Your Computer.”
Select “Perform Complete Scan.”
Follow the prompts to quarantine/remove the infected files.
Make sure to reboot following the scan.
If you are currently running a copy of SUPERAntiSpyware Professional, update the latest version/definition before running a scan and completing the quarantine/removal process.
Mike,
thank you for Notification...
Karma Up for You...  :up:
Best Regards,
ravi_and
 :up:Thanx for the information, and i'll right now downloading it.
