  • Total Topics: 16528
  • Online today: 3053
Guests: 3042
Total: 3045
Author Topic: McAfee VirusScan Enterprise 8.5i (Important) HotFix HF 472021  (Read 62574 times)
szn1
Re: McAfee VirusScan Enterprise 8.5i (Important) HotFix HF 472021
« Reply #10 on: 01. August 2009., 08:48:38 »
hi thanks for the link when i tried to install the patch, it says installer couldn't find any qualifying products...but i actually installed 8.5.0i.....could some one please help to install this....
« Reply #11 on: 01. August 2009., 09:31:29 »
Which Patch you have installed?
For this Hotfix you need to have latest one - Patch 8.
szn1
« Reply #12 on: 01. August 2009., 13:36:50 »
I installed the patch and hot fix still it got the same problem screen shot attached....just wondering did I d anything wrong?
« Reply #13 on: 01. August 2009., 15:55:26 »
Don't worry, everything is Ok with your AntiVirus now you have Patch 8. This is just Warning message that Vista Security Center isn't compatible with McAfee.
My advice is to Turn Off notification about that. Simply open Vista Security Center, open "Change the way Security Center alerts me", open Malware Protection and Click Turn Off.
« Reply #14 on: 01. August 2009., 16:51:55 »
You have here one similar case, so please read them carefully: http://scforum.info/index.php/topic,3039.0.html
kirangampala
« Reply #15 on: 01. August 2009., 17:13:40 »
Thanks for the hotfix Samker. I have installed it. It works fine.
rudelay
« Reply #16 on: 14. August 2009., 19:51:28 »
Many thanks for the link
rudelay
« Reply #17 on: 15. August 2009., 05:00:58 »
Why do I experience continuous installation interruption while installing patch 8, as well as Hotfix? I have recent version of virus scan 8.5i (5709xdat).
« Reply #18 on: 15. August 2009., 07:31:44 »
Hi R.,
I'll try to help you...
Please Use McAfee Virtual Technician: http://mvt.mcafee.com/mvt/default.asp
and provide us result and all possible information in New Topic in SCF "PC Help Center": http://scforum.info/index.php/board,16.0.html
gaurav400
« Reply #19 on: 16. August 2009., 02:44:21 »
Thanks Samker. Can you please clear that i should install the Patch 8 first and then run the this hotfix
