  • Total Topics: 16528
  • Online today: 3053
Guests: 3044
Total: 3047
Author Topic: McAfee VirusScan Enterprise 8.5i (Important) HotFix HF 472021  (Read 62573 times)
rudelay
Re: McAfee VirusScan Enterprise 8.5i (Important) HotFix HF 472021
« Reply #20 on: 16. August 2009., 05:48:51 »
It has worked, and thanks again. McAfee Virtual Technician showed that my engine version wasn't up-to-date, and when I did it worked. Now I want to update the Common Management Agent, and the files I downloaded have no setup, if not the FrmInst which prompted a page of many options while launched.
« Reply #21 on: 16. August 2009., 08:05:11 »
Thanks Samker. Can you please clear that i should install the Patch 8 first and then run the this hotfix
Yes. that is right.  ;)
That's good news.  :thumbsup:
leonrip
« Reply #22 on: 23. August 2009., 16:10:15 »
Hi,
Could you send me the hotfix link to download it please.
Thanks
hamid.sensini
« Reply #23 on: 30. August 2009., 18:18:42 »
thanks
devilishere
« Reply #24 on: 03. September 2009., 19:41:24 »
many thanks do send me the link
ajay15152003
« Reply #25 on: 04. September 2009., 14:03:58 »
Sir, Mam
I have download McAfee Virusscan Enterprise 8.5i , please send 10 digit password for the installation as soon as possible.
Thanxs & Regards
Ajay Kumar
9891728934
ajay15152003@yahoo.com
crojas1110
« Reply #26 on: 04. September 2009., 15:36:26 »
Disculpen pero necesito saber como diablos elimino el mensaje de McAfee 8.5i que dice "desbordamiento de buffer de escritura desbordamiento de buffer de pila", descargué el patch 8 pero sigue apareciendo, y ya no sé más descargar para eso. Agradezco su ayuda.
« Reply #27 on: 04. September 2009., 19:28:01 »
C. Máx
relacionados con su problema con que las cuestiones que les recomendaré a escanear su PC con algún antivirus en línea ...
Sospecho que su infectados con algún virus o gusano, tal vez incluso con Conficker.
Por favor, abra su propio tema en el SCF "PC" del Centro de Asistencia: http://scforum.info/index.php?action=forum
P.S.
Por favor, use Inglés allí ...
Para traducir este era utilizar Google Translate. ;-)
rceronp
« Reply #28 on: 08. September 2009., 15:29:21 »
Thanks a lot, would you send me the link to dowload te HotFix???
Triden
« Reply #29 on: 16. September 2009., 21:48:56 »
The hotfix can also be downloaded directly from McAfee without needing a grant number or login.
https://kc.mcafee.com/corporate/index?page=content&id=KB66032
The hotfix .zip is located at the bottom of the document.
