  • Total Topics: 16528
  • Online today: 3053
Guests: 3022
Total: 3025
Author Topic: McAfee VirusScan Enterprise Version 8.7i Patch 2 (Download)  (Read 162606 times)
tuntun
Re: McAfee VirusScan Enterprise Version 8.7i Patch 2 (Download)
« Reply #60 on: 11. October 2009., 14:27:55 »
In previous patch 1, I got some high CPU rate...How about this? Pls share with me before I deploy in network and want to know your feedback...Thanks
yagnesh
« Reply #61 on: 12. October 2009., 03:03:16 »
please let me know my pass  ???
« Reply #62 on: 12. October 2009., 06:56:27 »
Hi TT, here you have few Topics related to 8.7 version:
http://scforum.info/index.php/topic,3224.0.html
http://scforum.info/index.php/topic,2693.0.html
http://scforum.info/index.php/topic,1806.0.html
http://scforum.info/index.php/topic,2809.0.html
http://scforum.info/index.php/topic,1787.0.html
Jaxn
« Reply #63 on: 12. October 2009., 14:22:21 »
Hi Sam,
Good to be back. What version of AntiSpyware would you recommend with the latest 8.7 version patch2. Patch 1 has memory leaks issue and was fixed by patch 2. And by the way, do you recommend doing a complete removal of older version by using McAfee removal tool with no trace and do a clean install. Got your email about the update to a newer version, can u please send the PW for patch 1 and 2 please.
Thanks
Jaxn
« Reply #64 on: 12. October 2009., 17:26:54 »
Hi J., nice to see you again. ;)
You just need to run this Upgrade and (probably) everything will be resolved with this "memory"issue...
My preferred AS are: MalwareBytes, SUPERAntiSpyware, Spybot S&D...
Please increase your post number to at least 25 and Amker will send you pass., just look around SCF and you'll find a lot of very intersting Topics for comment.
Best Regards,
tetora
« Reply #65 on: 12. October 2009., 18:55:31 »
Thankyou
b_gates
« Reply #66 on: 13. October 2009., 01:27:30 »
Thanks for this topic.
May I have password Please?
b_gates
« Reply #67 on: 13. October 2009., 01:51:36 »
Is this update only for Patch 1?
by the way I 've McAfee.VirusScan.Enterprise.v8.7i.Patch.1-DVT; it's 122 MB' How can I install Patch 2?
Is that right to install "McAfee.VirusScan.Enterprise.v8.7i.Patch.1-DVT" and then install Patch 2 update? or what?!!
Jaxn
« Reply #68 on: 13. October 2009., 02:44:23 »
Hi Sam
I think one needs to do a clean install to have 8.7i. Remove the previous version by using McAfee removal tool and then have 8.7i followed by patches 1 and 2. Configuration setting will be retained if just patched rather than doing a clean install from 8.7i patch1 and then 8.7i patch2. Please let know.
Thanks
J
« Reply #69 on: 13. October 2009., 07:11:53 »
I'm 99% sure that Patch 2 is cumulative (it include all fixes from earlier verison 1) so you just try to "run" Patch 2 and let us know is everything Ok.
Regards to both,
P.S.
Since English isn't my first language sorry if I was make some grammatical mistakes... ;)
