  • Total Topics: 17056
  • Online today: 12869
Guests: 12866
Total: 12868
Author Topic: Help with vbscript  (Read 5766 times)
F3RL
Help with vbscript
« on: 20. November 2009., 23:56:48 »
Hi,
I got this vbscript that clears system tray notification icons by deleting two registry entries.
The problem is I want to execute this when logging off but it displays two messages;
and I want someone to instruct me how to remove that message but continue executing the script.
here is the script;
Message = "To work correctly, the script will close" & vbCR
Message = Message & "and restart the Windows Explorer shell." & vbCR
Message = Message & "This will not harm your system." & vbCR & vbCR
Message = Message & "Continue?"
X = MsgBox(Message, vbYesNo, "Notice")
If X = 6 Then
On Error Resume Next
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.RegDelete "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\TrayNotify\IconStreams"
WshShell.RegDelete "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\TrayNotify\PastIconsStream"
Set WshShell = Nothing
On Error GoTo 0
For Each Process in GetObject("winmgmts:"). _
   ExecQuery ("select * from Win32_Process where name='explorer.exe'")
   Process.terminate(0)
Next
MsgBox "Finished." & vbcr & vbcr & "© Doug Knox and Kelly Theriot", 4096, "Done"
Else
MsgBox "No changes were made to your system." & vbcr & vbcr & "© Doug Knox and Kelly Theriot", 4096, "User Cancelled"
End If
Can you help me remove the message popups?
Thank you in advance.
Help with vbscript
hazedaze
Re: Help with vbscript
« Reply #1 on: 18. January 2010., 13:58:31 »
OMG I'm trying to rember my VB days at College!!!lol
If my thinking is correct can't you simply put "REM" at the begining of the Msgbox sentence,
Your Code for example Would Read:
If X = 6 Then
On Error GoTo 0
Next
Rem MsgBox "Finished." & vbcr & vbcr & "© Doug Knox and Kelly Theriot", 4096, "Done"
Else
Rem MsgBox "No changes were made to your system." & vbcr & vbcr & "© Doug Knox and Kelly Theriot", 4096, "User Cancelled"
End If
