  • Total Topics: 17039
  • Online today: 16460
Guests: 16458
Total: 16459
Author Topic: Your Freedom: Stay anonymous  (Read 6659 times)
F3RL
« on: 21. November 2009., 04:12:34 »
Are you trapped behind a firewall or a filtering web proxy and cannot access some or many web pages or use an application you would like to use or play a game you would like to play? Is your Internet connection being censored and you would like to stick censorship where the sun doesn't shine? Would you prefer to stay anonymous, that your IP address is not logged with every access to someone's web page? Then look no further, you've found the solution!
The Your Freedom services makes accessible what is unaccessible to you, and it hides your network address from those who don't need to know. Just download our client application and install or just run it on your PC; it turns your own PC into an uncensored, anonymous web proxy and an uncensored, anonymous SOCKS proxy that your applications can use, and if that's not enough it can even get you connected to the Internet just as if you were using an unrestricted DSL or cable connection -- just like the firewall suddenly went boom! You can even make your PC accessible from the Internet if you like. Nearly all applications work with Your Freedom, and so far no-one has managed to block our service completely and permanently without blocking your Internet access entirely.
Source: http://www.your-freedom.net/
Please note that the maximum speed you'd get is approximately 8kB/s (free users) unless you purchase the boucher to get an unlimited speed. Anyway, hope it was useful to those who seeks anonymity ;)
Eric.
Re: Your Freedom: Stay anonymous
« Reply #1 on: 21. November 2009., 07:57:24 »
Thanks Eric, very valuable Topic...  :up:
jhonas
« Reply #2 on: 08. January 2011., 08:17:56 »
Thanks for this informative post.
