  • Total Topics: 17039
  • Online today: 20252
Guests: 20244
Total: 20245
Author Topic: Error in Sweet Home 3D (Please update DirectX/OpenGL drivers...)  (Read 87114 times)
Oriolus
After installing Sweet Home 3D (suggested by a friend using a Mac), and running the program for the first time results in a fatal error in 3D rendering system. It suggests:
Please update DirectX/OpenGL drivers of your computer graphics card.
How can I find the right place to obtain the right drivers? And, how could my drivers not be up to date, since I recently got a new mother board, and thus a new graphics card with the newest drivers, I presume?
Re: Error in Sweet Home 3D
« Reply #1 on: 08. January 2010., 21:54:44 »
Hi Oriolus.
This program looks fantastic my friend: http://www.sweethome3d.eu/
Don't worry We'll help you to resolve this problem, for the start We need information about your Graphics Card (manufacture, series etc.) and Driver which is installed right now??
bigwave77
Re: Error in Sweet Home 3D (Please update DirectX/OpenGL drivers...)
« Reply #2 on: 10. January 2010., 20:09:42 »
I have the same problem and i have
mobile intel(R) 945gm express chipset family
driver version 6.14.10.4814
also i was working on a very important file that now seems to have no data in the file and was hoping you might have info on how to recover
Hi Bigwawe and Welcome to SCF Community.
We'll do our best to help you also... please give us information's which Operating system You use and how this problem occur?
Best Regards,
bigwave77
« Reply #4 on: 11. January 2010., 16:22:46 »
windows xp pro version 2002 service pack 3
I had just finished saving my seconds file on sweet home 3D, by the way is a fantastic program, but the next time I tried to open one of my saved files the file opened and i could see it and thats when i got the error message to update my directX/open gl drivers of computer graphic card.
    and when I tried to open the second saved file it said it couldn't open it and when i looked at the file it had 0 bites of info in it. Would sure like to find what happen to that file
« Reply #5 on: 11. January 2010., 19:52:24 »
Ok Bigwave. As I see you use one outdated driver?
Please check here for latest XP version "14.​​32.​​4.​​4926": http://www.intel.com/support/chipsets/sb/CS-022034.htm
After that, read carefully suggestions from Sweet Home 3D Official FAQ "I got the message Sweet Home 3D will exit now because of a fatal error in 3D rendering system. What can I do?"
: http://www.sweethome3d.eu/faq.jsp
Hope this will help you??
Best Regards,
Oriolus
« Reply #6 on: 12. January 2010., 23:14:11 »
Hi S,
Thank you for your kindly outstretched hand!
I've been searching how to find what card I have. I use Windows Vista Home Premium, but I cannot find where I can retrieve my graphics card. In a flash ASUS P5V2 (or something) is shown when I start my computer... Stupid ???, sorry!
« Reply #7 on: 13. January 2010., 15:07:20 »
No problem my friend... ;)
The easiest way to find out on Windows (if drivers are installed):
   1. Go to your Desktop;
   2. Right click on your background and click Properties;
   3. Click on Settings and look under "Display" - it should state your graphic card model.
Or
   1. Go to Start;
   2. Right click on my computer and select Properties;
   3. Select the "Hardware" tab, and press Device Processing;
   4. Go down to Screen card (Click the +).
If you already have the proper graphics card drivers installed:
Go to Start, then Run and type "dxdiag." That will show you information about your computer as well as about your video card type. You can also get this information from the device manager.
If you don't have the proper graphics card drivers installed:
   1. Shut down and unplug the computer;
   2. Remove the outer casing;
   3. If possible carefully remove the graphics card;
   4. Read the model number off the card.
   5. Replace the graphics card.
   6. Close the casing
   7. Power up the computer.
   8. Look on the manufacturer's website for the exact name of the hardware
If you don't have the proper graphics card drivers installed and don't want to open up the computer:
There are several programs available which can tell you the pnp (plug and play) info from the card itself. Using this information, plus a little googling, it should be easy to determine what video card you have.
To find out ALL your system settings:
Download a program called "Everest Freeware Edition": http://www.lavalys.com/products.php?lang=en&page=11
Hope this will help you, since we need that info's?
Also please check my reply to "Bigwave" (above), since you both have similar problems??
Oriolus
« Reply #8 on: 15. January 2010., 18:29:45 »
I hope this is the information you need to help me:
VIA Chrome9 HC IGP WDDM
C:\Windows\system32\DRIVERS\VTGKmodelDX32.sys
C:\Windows\system32\VTGOGL32.DLL
C:\Windows\system32\VTGUModelDX32.dll
Results dxdiag:
(I ordered the report to be in English, but it persisted in showing me the report in Dutch. I hope this well do for you?)
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
    Versie                                            EVEREST v5.30.1900/nl
    Benchmark Module                                  2.4.273.0
    Startpagina                                       http://www.lavalys.com/
    Rapporttype                                       Snelrapport [ TRIAL VERSION ]
    Computer                                          SILVERBOX
    Maker                                             LieMaa
    Besturingssysteem                                 Microsoft Windows Vista Home Premium 6.0.6002 (Vista RTM)
    Datum                                             2010-01-15
    Tijd                                              16:04
--------[ GPU ]---------------------------------------------------------------------------------------------------------
  [ Geïntegreerd: VIA Chrome9 HC Integrated ]
    Grafische Processor Eigenschappen:
      Video kaart                                       VIA Chrome9 HC Integrated
      GPU Codenaam                                      Chrome9
      PCI-apparaat                                      1106-3371 / 1043-8252  (Rev 01)
      Bus Type                                          Geïntegreerd
      GPU Klok                                          251 Mhz
      RAMDAC kloksnelheid                               350 Mhz
      Pixel Pipelines                                   2
      TMU Per Pipeline                                  1
      Vertex Shaders                                    1  (v2.0)
      Pixel Shaders                                     2  (v2.0)
      DirectX hardware ondersteuning                    DirectX v9.0
      Pixel vulsnelheid                                 502 MPixel/s
      Texel vulsnelheid                                 [ TRIAL VERSION ]
    Geheugenbus-Eigenschappen:
      Bus Type                                          DDR
      Bus Breedte                                       64 bit
      Werkelijke kloksnelheid                           333 Mhz (DDR)
      Effectieve kloksnelheid                           667 Mhz
      Bandbreedte                                       [ TRIAL VERSION ]
    Frabrikant Grafische processor:
      Firmanaam                                         VIA Technologies, Inc.
      Productinformatie                                 http://www.via.com.tw/en/products/graphics
      Driver download                                   http://www.viaarena.com/?PageID=70
      Driver Update                                     http://driveragent.com?ref=59
    VIA GPU Registers:
      viac-44                                           CC
      viac-45                                           08
      viac-46                                           03
      viac-47                                           AD
      viac-48                                           04
      viac-49                                           03
      viac-4A                                           52
      viac-4B                                           90
      viac-4C                                           01
      viac-4D                                           00
      viac-4E                                           00
      viac-4F                                           5F
      viad-3D                                           84
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
    B00 D00 F00:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - System Controller
      Offset 000:  06 11 64 03  06 01 10 02  00 00 00 06  00 08 80 00
      Offset 010:  08 00 00 F0  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  43 10 52 82
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  40 33 04 00  00 00 00 00  00 00 1F C4  00 24 00 01
      Offset 050:  01 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  02 50 35 00  0B 02 00 07  02 03 00 00  00 00 00 00
      Offset 090:  80 01 00 00  20 0F 01 00  00 80 80 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 03 00 00  00 00 00 00  25 02 00 0C
      Offset 0C0:  00 00 80 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D00 F01:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - ECC Controller
      Offset 000:  06 11 64 13  06 00 00 02  00 00 00 06  00 00 00 00
      Offset 010:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 090:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D00 F02:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - Host Bus Interface
      Offset 000:  06 11 64 23  06 00 00 02  00 00 00 06  00 00 00 00
      Offset 050:  88 F8 EF 88  9C 08 00 A1  00 20 00 00  00 B2 88 06
      Offset 060:  A5 A5 00 55  55 00 33 00  01 02 00 00  00 00 00 00
      Offset 070:  33 55 33 55  35 20 74 00  10 AA 24 00  00 B5 00 00
      Offset 080:  2D 10 10 10  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 0E 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D00 F03:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - DRAM Controller
      Offset 000:  06 11 64 33  06 00 00 02  00 00 00 06  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  08 10 20 30  00 00 00 00  00 08 10 20  00 00 00 00
      Offset 050:  2A 00 11 9F  89 AB 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 63 AB 69  66 D9 88 00  00 8F A8 10  C8 C0 88 43
      Offset 070:  00 01 00 00  04 04 C1 8A  8D 80 00 3C  00 00 00 00
      Offset 080:  2A 00 FF 20  00 C0 39 00  C0 00 00 00  00 00 00 00
      Offset 090:  05 07 05 05  00 00 00 00  F8 00 00 00  0A 00 91 00
      Offset 0A0:  00 DC 44 00  01 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  83 AA 02 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0D0:  88 99 98 01  8A A0 A8 00  00 00 00 00  00 00 00 00
      Offset 0E0:  EE 00 CB 00  66 00 FF 00  DB 00 00 00  88 00 00 30
      Offset 0F0:  00 00 00 00  00 00 00 00  00 00 60 00  00 00 00 00
    B00 D00 F04:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - Power Management Controller
      Offset 000:  06 11 64 43  06 00 00 02  00 00 00 06  00 00 00 00
      Offset 090:  F8 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  80 A0 3F FF  FF F0 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 80 00  80 00 00 00  F1 00 04 00  00 00 00 00
      Offset 0F0:  00 00 00 00  00 00 05 00  00 00 00 00  00 00 00 00
    B00 D00 F05:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - I/O APIC Interrupt Controller
      Offset 000:  06 11 64 53  06 00 00 00  00 20 00 08  00 00 80 00
      Offset 040:  CC 00 05 00  02 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  2B 0E 00 00  13 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  F7 00 30 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  C0 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0F0:  62 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D00 F06:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - Security Device
      Offset 000:  06 11 64 63  06 00 00 00  00 00 00 06  00 00 80 00
      Offset 040:  00 00 00 00  60 00 0A 00  00 00 00 00  00 00 00 00
      Offset 050:  0F 00 00 00  00 02 19 00  08 08 10 10  00 00 00 00
      Offset 060:  00 00 00 00  00 00 00 00  00 09 12 1B  00 00 00 00
      Offset 070:  22 22 2A 2A  00 00 00 00  08 08 10 10  00 00 00 00
    B00 D00 F07:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - V-Link Bus Interface
      Offset 000:  06 11 64 73  06 00 00 02  00 00 00 06  00 00 00 00
      Offset 040:  70 19 88 88  82 44 10 10  00 00 00 00  00 00 00 00
      Offset 0B0:  01 01 00 13  77 86 88 64  00 00 00 00  00 00 00 00
    B00 D01 F00:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - AGP Controller
      Offset 000:  06 11 98 B1  07 00 30 02  00 00 04 06  08 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  00 01 01 00  F0 00 20 02
      Offset 020:  00 FA E0 FB  00 C0 F0 DF  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  70 00 00 00  00 00 00 00  00 00 1B 00
      Offset 040:  93 CB 02 66  30 72 00 00  00 00 00 00  00 00 00 00
      Offset 070:  01 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  0E 70 35 00  07 02 00 1F  00 00 00 00  28 00 00 00
      Offset 090:  80 00 00 00  00 08 01 00  00 00 00 00  00 00 00 00
      Offset 0B0:  80 63 08 00  00 00 00 00  00 00 1F C4  00 04 00 00
      Offset 0C0:  08 00 0B FF  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D02 F00:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - PCI Express Port 1
      Offset 000:  06 11 64 A3  04 01 10 00  80 00 04 06  08 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  00 02 02 00  F0 00 00 00
      Offset 020:  F0 FF 00 00  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  40 00 00 00  00 00 00 00  1B 01 03 00
      Offset 040:  10 68 41 01  01 80 00 00  10 00 10 00  01 3D 18 00
      Offset 050:  00 00 01 10  E0 25 80 00  38 10 00 00  08 00 00 00
      Offset 060:  00 00 00 00  00 00 00 00  01 70 22 C8  00 00 00 00
      Offset 070:  05 88 80 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  00 00 00 00  08 98 02 A8  00 00 00 00
      Offset 090:  00 00 00 00  00 00 00 00  0D 00 00 00  06 11 23 C3
      Offset 0A0:  10 14 30 FC  7E FF 7F AC  00 00 00 00  00 00 00 00
      Offset 0B0:  0C 12 41 81  00 00 21 00  00 00 00 00  00 00 00 00
      Offset 0C0:  03 00 25 00  44 44 44 44  44 44 44 44  00 00 00 00
      Offset 0D0:  50 20 00 00  00 00 00 00  00 00 00 00  08 00 02 A8
      Offset 0E0:  0C 0B A4 94  06 00 00 00  84 A4 46 00  00 00 00 00
      Offset 0F0:  00 00 00 06  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D03 F00:  VIA CN896/P4M900/PT890Pro/VN896 Chipset - PCI Express Port 2
      Offset 000:  06 11 64 C3  04 01 10 00  80 00 04 06  08 00 81 00
      Offset 010:  00 00 00 00  00 00 00 00  00 03 03 00  F0 00 00 00
      Offset 030:  00 00 00 00  40 00 00 00  00 00 00 00  1F 01 03 00
      Offset 040:  10 68 41 01  01 80 00 00  10 00 10 00  11 3C 18 01
      Offset 050:  00 00 01 10  E0 25 C0 00  38 10 00 00  08 00 00 00
      Offset 0A0:  10 14 70 7C  5C FF 7F AC  00 00 00 00  00 00 00 00
      Offset 0B0:  0C 12 40 81  00 00 01 00  00 00 00 00  00 00 00 00
      Offset 0C0:  03 00 27 00  44 44 00 00  00 00 00 00  00 00 00 00
      Offset 0D0:  50 20 00 00  02 00 00 00  00 00 00 00  08 00 02 A8
      Offset 0E0:  00 0F 24 94  48 00 00 00  00 00 00 00  00 00 00 00
    B00 D0F F00:  VIA SATA Controller
      Offset 000:  06 11 72 53  05 00 90 02  00 8F 01 01  00 40 80 00
      Offset 010:  01 EC 00 00  81 E8 00 00  01 E8 00 00  81 E4 00 00
      Offset 020:  01 E4 00 00  01 E0 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  C0 00 00 00  00 00 00 00  15 02 00 00
      Offset 040:  23 13 F1 44  07 AF 00 00  00 80 00 00  00 81 00 00
      Offset 050:  00 00 00 00  00 00 02 00  00 10 80 10  00 00 20 11
      Offset 060:  00 00 00 00  49 CB CC 60  66 00 0F 04  44 00 51 61
      Offset 070:  46 00 00 00  00 00 00 00  15 00 01 00  00 00 00 00
      Offset 080:  40 00 00 30  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  13 00 13 00  0C 0C 0C 0C  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 07 04  00 00 00 00  00 00 07 04  00 00 00 00
      Offset 0C0:  01 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0D0:  00 02 72 53  43 10 7C 82  00 00 72 73  00 00 00 00
      Offset 0F0:  00 00 00 00  09 00 00 00  00 00 00 00  00 00 00 80
    B00 D0F F01:  VIA VT8237S IDE Controller
      Offset 000:  06 11 71 05  05 00 90 02  07 8A 01 01  00 20 00 00
      Offset 020:  01 FC 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  C0 00 00 00  00 00 00 00  FF 00 00 00
      Offset 040:  0B F2 09 05  18 8C C4 00  A8 A8 A8 20  FF 00 B6 B6
      Offset 050:  07 07 17 F2  0C 03 00 00  A8 A8 A8 A8  00 00 00 00
      Offset 060:  00 02 00 00  00 00 00 00  00 02 00 00  00 00 00 00
      Offset 070:  02 01 25 00  00 00 00 00  82 01 00 00  00 00 00 00
      Offset 0D0:  07 01 71 05  43 10 7C 82  00 00 00 00  00 00 00 00
    B00 D10 F00:  VIA VT8237S USB Universal Host Controller
      Offset 000:  06 11 38 30  15 00 10 02  B0 00 03 0C  08 40 80 00
      Offset 020:  81 D4 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  14 01 00 00
      Offset 040:  40 12 03 00  00 00 00 00  00 0B A0 0B  00 00 00 00
      Offset 060:  10 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  01 00 C2 FF  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  00 20 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D10 F01:  VIA VT8237S USB Universal Host Controller
      Offset 020:  01 D8 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  16 02 00 00
    B00 D10 F02:  VIA VT8237S USB Universal Host Controller
      Offset 020:  81 D8 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  15 03 00 00
    B00 D10 F03:  VIA VT8237S USB Universal Host Controller
      Offset 020:  01 DC 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  17 04 00 00
    B00 D10 F04:  VIA VT8237S USB 2.0 Enhanced Host Controller
      Offset 000:  06 11 04 31  16 00 10 02  90 20 03 0C  08 40 80 00
      Offset 010:  00 FC FF F9  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  43 10 7C 82
      Offset 040:  00 00 03 00  00 00 00 00  9E 60 00 09  12 8C 00 00
      Offset 050:  00 60 00 F0  00 00 00 00  04 0B 88 88  03 88 88 00
      Offset 060:  20 20 01 00  00 00 00 00  01 00 00 00  00 20 00 C0
      Offset 080:  01 88 C2 FF  00 00 00 00  0A 00 A0 20  00 00 00 00
      Offset 0F0:  00 00 00 00  00 00 B0 00  00 00 00 00  00 00 00 00
    B00 D11 F00:  VIA VT8237S PCI-ISA Bridge
      Offset 000:  06 11 72 33  03 00 10 02  00 00 01 06  00 00 80 00
      Offset 030:  00 00 00 00  C0 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  44 40 F4 0B  00 00 10 00  0C 20 00 00  44 00 0A 00
      Offset 050:  C0 1D 09 00  00 00 00 00  62 80 00 03  00 00 00 00
      Offset 060:  00 00 00 09  00 F0 08 05  80 00 D0 FE  00 00 00 00
      Offset 070:  43 10 7C 82  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  20 84 59 00  88 00 00 00  01 08 00 00  05 18 00 00
      Offset 090:  00 FF EE 88  20 C1 04 02  00 FF FF 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 00 00 00  00 00 00 00  20 D0 FE 00
      Offset 0D0:  01 04 05 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0E0:  00 00 0E 00  A1 69 EF 8E  00 10 D0 FE  07 00 00 00
      Offset 0F0:  00 00 00 00  00 00 02 00  00 00 00 00  00 00 00 00
    B00 D11 F07:  VIA VT8237S Ultra V-Link Controller
      Offset 000:  06 11 7E 28  06 01 10 02  00 00 00 06  00 80 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 7E 33
      Offset 030:  00 00 00 00  58 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  F4 24 00 80  82 00 00 00  13 3B 88 80  82 44 80 43
      Offset 050:  80 8F D3 01  00 04 01 C0  08 00 01 80  00 00 00 00
      Offset 060:  00 2A 00 20  FF 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  82 C8 EE 01  3C 0F 50 48  01 00 00 00  02 00 12 12
      Offset 080:  08 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  FD 3F DF 00  00 00 00 E0  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 00 00 60  42 88 88 81  00 03 00 00
      Offset 0C0:  01 00 02 00  00 00 00 00  0C 06 00 00  00 00 00 00
      Offset 0E0:  00 00 00 00  00 C0 39 00  00 00 00 00  00 00 00 00
      Offset 0F0:  00 00 00 00  00 00 00 00  00 00 00 00  04 00 00 00
    B00 D12 F00:  VIA VT6102 Rhine II Fast Ethernet Adapter
      Offset 000:  06 11 65 30  17 01 10 02  7C 00 00 02  08 40 00 00
      Offset 010:  01 D0 00 00  00 F8 FF F9  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  43 10 ED 80
      Offset 030:  00 00 00 00  40 00 00 00  00 00 00 00  17 01 03 08
      Offset 040:  01 00 02 FE  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  00 00 80 05  00 00 00 00  00 00 00 00  65 30 00 00
    B00 D13 F00:  VIA VT8237A PCI to PCI Express Bridge
      Offset 000:  06 11 7B 33  06 01 10 20  00 00 00 06  00 00 80 00
      Offset 030:  00 00 00 00  60 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  02 00 06 06  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  08 00 02 A8  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  0D 00 00 00  43 10 7C 82  00 00 00 00  00 00 00 00
    B00 D13 F01:  VIA VT8237A PCI-PCI Bridge
      Offset 000:  06 11 7A 33  07 01 10 20  00 01 04 06  00 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  00 04 04 00  F0 00 00 02
      Offset 030:  00 00 00 00  60 00 00 00  00 00 00 00  00 00 03 00
      Offset 060:  08 70 02 A8  00 00 00 00  00 00 00 00  00 00 00 00
    B01 D00 F00:  VIA Chrome9 HC Integrated Video Adapter
      Offset 000:  06 11 71 33  07 00 30 02  01 00 00 03  00 40 00 00
      Offset 010:  08 00 00 C0  00 00 00 FA  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  60 00 00 00  00 00 00 00  10 01 02 00
      Offset 060:  01 70 22 06  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  02 00 30 00  0B 1E 00 FF  02 03 00 07  00 00 00 00
    B27 D04 F00:  Unknown
      Offset 000:  43 10 52 82  80 00 00 00  00 00 00 00  FF FF FF FF
      Offset 010:  FF FF FF FF  80 01 00 00  06 11 64 03  00 00 00 06
      Offset 020:  08 00 00 F0  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
      Offset 040:  80 01 00 00  06 11 64 03  00 00 00 06  08 00 00 F0
      Offset 060:  00 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 070:  06 01 10 02  00 08 80 00  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  43 10 52 82  80 00 00 00  00 00 00 00
      Offset 090:  02 50 35 00  80 01 00 00  FF FF FF FF  FF FF FF FF
      Offset 0A0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0B0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0C0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0D0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0E0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0F0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    B80 D01 F00:  VIA VT8237S High Definition Audio Controller
      Offset 000:  06 11 88 32  06 00 10 00  10 00 03 04  08 00 00 00
      Offset 010:  04 C0 FF FB  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  43 10 90 82
      Offset 030:  00 00 00 00  50 00 00 00  00 00 00 00  11 01 00 00
      Offset 040:  20 30 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  01 60 42 C8  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  05 70 80 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  10 00 91 00  00 00 00 00  00 00 30 00  00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
    C000:0000  U.L...3h................D..mG.IBM COMPATIBLEBCPOST....11/30/06..
    C000:0040  ....PCIR..q3........@.Q.......   VIA TRC46M....*VT3364   Desktop
    C000:0080    NoTV ....Ver08.....       ..V.....\...O...O..._...O.^...U....j
    C000:00C0  ..h...B..t...h.@...B...h.....h........e...........".......|."...
    C000:0100  ~...........................`.......R...k.....R.2....e.Z...R.;..
    C000:0140  ...W.Z.......,......u..&..........u.......,..=..........w.f.....
    C000:0180  ......v.3..>r.4.t..}..+k.O..x..+......t......].ziR.=.........Z..
    C000:01C0  .......N.....2h.....u...h.>.....B..u..>@....0.....u... .&....&..
    C000:0200  2........D. D.@^....i..B...........t........t...i......<.t....t.
    C000:0240  ..T.......i.....i..i..i.|i..i.....s..................B..u.......
    C000:0280  u.. ......t.$........P3.2........e..c....3......t.3......u......
    C000:02C0  ...*.X..$;......................................................
    C000:0300  ..........................................~......~~......~l...|8
    C000:0340  ...8|.|8..8|8..|8|..8|.|8|...<<............<fBBf<............}..
    C000:0380  .x<fff<.~.?3?00p..cccg...Z<..<Z...........>.>....<~..~<.fffff.
    C000:03C0  f...{....>c8ll8.x....~~~..<~.~<...<~.........~<...........0`.`0
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
    PCI/AGP         1043-8252 [SubSys: 0000-0000]: Unknown
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
End of report.
I hope I chose the right subset of information that is necessary to judge about the graphics card?
Thanks in advance,
Oriolus
Download latest driver VIA Chrome9 and the Hyperion Pro
« Reply #9 on: 16. January 2010., 21:01:31 »
Ok Oriolus, you have Via Chrome9 HC (very weak) integrated graphics...
Here is latest driver version 21.09.01h: http://www.viaarena.com/Driver/P4M900(CE)-VN896(CE)-CN896(CE)_210901h_Vista_wIShld.zip
The Hyperion Pro driver is also recommended, download them from here: http://www.viaarena.com/Driver/VIA_HyperionPro_V524A.zip
To install the driver, save any unsaved work and close all applications. Download driver and Unzip the file (To unzip the file right click and highlight "Extract All"). Then double click on the Setup.exe file to run the installation program. Follow the prompts and restart at the end of the installation.
But since the Chrome 9 HC graphics HARDWARE is basically weak, no amount of software update or intervention could bring it up to speed for PC gaming.
Maybe that cause all this mess and you'll need to buy some "better" graphic card.
I'll wait news from... ;)
