  • Total Topics: 17039
  • Online today: 16260
Guests: 16260
Total: 16261
Author Topic: Outpost Firewall Pro 4.0 (1024.700.292)  (Read 11759 times)
« on: 25. June 2007., 12:52:09 »
Outpost Firewall Pro is acknowledged as one of the most secure and easy to use firewall software solutions. Outpost Firewall Pro provides the following safeguards:
- Protection against hacker attacks;
- Protection against Internet worms;
- Protection of sensitive and valuable information and data;
- Protection of private information and maintenance of Web privacy;
- Monitoring of the system and application network activity.
Outpost firewall automatically configures itself during installation and optimizes its configuration to match the system on which it is installed. Furthermore, you don’t need to worry about keeping your protection up-to-date because Outpost features an automatic update utility, which keeps Outpost current and ready to avert network intruders.
Outpost Firewall Pro provides a superior arsenal of defense against PC infiltration by denying unauthorized access by remote hackers and protecting against data theft, denial-of-service attacks, privacy violation, Trojan horses, spyware and more. Four major criteria define Outpost Firewall Pro: security, control, privacy and ease of use. Some major features of Outpost are listed below:
Security Features
- Attack Detection Plug-in:
* averts and reports all known kinds of attacks against the system
* port scan detection
- Attachment Quarantine guards against dangerous attachments and worms;
- Components Control (Anti-Leak) feature monitors components of each application on the system;
- Stateful Inspection firewall technology provides superior security to packet filtering;
- Windows Boot-up protection defends the system before any malicious programs can be loaded;
Control Features
- Network activity monitoring;
- Log Viewer
- Filtering of web content
- One click to block all traffic or disable the firewall;
Privacy Features
- Active Content plug-in:
- Flexible web history (referrers) blocking
- Flexible blocking of cookies and other active elements;
- Trusted Sites list;
- Blocking of banners (including Flash ads) and pop-up window;
- Hidden Process Control and Component Control: blocks spyware connections
Ease of Use and Compatibility
- Auto-configuration of rules for applications during installation;
- Predefined system and application settings cover all common tasks such as browsing the web, allowing ICQ, allowing DNS or DHCP, etc;
- Seamless migration from earlier versions with the help of Agnitum Update;
- Wizard mode simplifies automatic rule creation;
Changes in Outpost Firewall Pro 4.0.1024.700 (June 22, 2007) :
- Error occurred on uninstalling Debug plugin if Outpost Firewall was running installing third-party applications
- Outpost Firewall blocked third-party applications setup programs
- Outpost Firewall now detects attempts to install over the later version
- Outpost Firewall could freeze on starting
- Outpost Firewall could freeze on detecting critical system object change
- Recurring critical system object change could not be detected
- Outpost Firewall could crash if working concurrently with "World of Warcraft"
Download : 32 bit
http://dl2.agnitum.com/OutpostProInstall.exe
Download : 64 bit
http://dl2.agnitum.com/OutpostProInstall64.exe
