  • Total Topics: 17027
  • Online today: 68623
Guests: 64859
Total: 64859
Author Topic: Anti-virus suites still can't block Google China attack  (Read 4378 times)
Analysis The vast majority of consumer anti-virus products are still failing to block the Operation Aurora exploits used in the high profile attack against Google and other blue-chip firms last December, according to independent tests.
NSS Labs evaluated the effectiveness of seven popular consumer endpoint security products to see which blocked variants of the Operation Aurora attack. The security testing firm reckoned that most, if not all, of the products would block the exploit and malicious code payloads associated with an ultra-high profile attack that has been a mainstay of talk in the information security biz for the last six weeks.
However, only security software from McAfee out of all the seven tested products "correctly thwarted multiple exploits and payloads, demonstrating vulnerability-based protection", NSS discovered to its surprise. Other tested security suites - AVG Internet Security, ESET Smart Security 4, Kaspersky Internet Security, Norton Internet Security 2010, Sophos Endpoint Protection for Enterprise and Trend Micro Internet Security 2010 - all failed.
NSS Labs argues that its research, unveiled at the BSidesAustin security conference on Saturday - highlights the importance of providing greater vulnerability-based protection.
"Rather than reactively blocking individual exploits or malware, vendors should focus on minimizing their customers’ risk of exposure by insulating the vulnerability," Rick Moy, president of NSS Labs explained in a statement: http://www.prweb.com/releases/2010/03/prweb3721474.htm
The research has received a mixed reception from security vendors. Trend Micro, which received a thumbs-down in the test, nonetheless welcomed the research.
"NSS Labs is building up a series of tests that measure the protection at various 'protection layers'," said Anthony Arrott, product manager of security analytics at Trend Micro. "Individually, these tests do not attempt to measure end-to-end protection across all layers – ultimately what matters most to users."
Modern endpoint protection products rely on multiple layers of protection - including malicious attachment blocking, preventing access to malicious URLs and behaviour blocking as well as shielding the underlying vulnerability on the endpoint from being exploited - but the NSS tests only looked at the last of these layers, in concluding that only one in seven tested products snuffed out the exploit.
"Trend Micro agrees with this assessment. This is why Trend Micro recently acquired Third Brigade and is currently integrating the Canadian firm's excellent vulnerability layer protection technology into Trend Micro's enterprise and consumer products," Arrott told El Reg.
"Trend Micro is looking forward to the day when the independent security product testing laboratories develop tests that measure the end-to-end protection provided against threats regardless which layer thwarts the threat."
Non-vulnerability-shielding countermeasures in Trend Micro's arsenal already block the threat, he added: http://blog.trendmicro.com/trend-micro-to-help-proactively-protect-against-zero-day-attacks-like-the-recent-ie-explorer-exploit
Come and AVG a go
NSS' blog post on the tests includes a video illustrating how security software from AVG flunked the test: http://nsslabs.blogspot.com/2010/03/exploits-occur-in-memory.html
AVG took exception to the exercise and posted a blog saying the tests were wrong. "AVG software stops the Aurora attacks just fine - in fact three different security rules of our software stop it," AVG argues: http://viruslab.blog.avg.com/2010/03/nss-labs-questionable-report.html
The security firm, famous for its free-of-charge consumer security scanner, also criticised NSS for attempting to charge vendors for more information on how it ran its tests.
NSS responded to this post with its own broadside on Tuesday, defending its methodology and arguing that AVG's blog post showed the blocking of the exploit for surfers using Firefox - not IE - which is where problems arise: http://nsslabs.blogspot.com/2010/03/whoosh-avg-swings-and-misses.html
Doing the business
Luis Corrons, technical director of PandaLabs, expressed concern that NSS tests were potentially misleading. Six of the seven tested products were designed for consumers, while the Aurora attack was targeting big companies, which use corporate antivirus products quite distinct from those used by consumers. Corporates have different protection layers (gateways, endpoint, etc.) but the NSS tests only looked at one layer of protection.
"A major issue is that product configuration is different, as the needs for corporate and consumer users are different, so a different result may be obtained depending on the product used in the test," Corrons explained. "For example, in a corporate environment it's common to block the http downloads of any packed file (malware is usually packed), but you'll rarely see that on a consumer product, as many games also use packers."
Moy acknowledged Panda had a point. "More extensive testing is being done on enterprise versions of these products and will be available to our clients in a few weeks," the NSS boss told El Reg. "We discussed the approach and testing with many of the vendors and other noted researchers with broad support for the initiative."
"The research was part of other independent testing work we were already performing when the Aurora attack became public. We performed and released the results to highlight issues that all endpoint security product users need to be aware of."
(Register)
Updated
McAfee's software is not the only product capable of blocking Aurora at the first line of defence. F-Secure Exploit Shield, which is the part of the product that provides vulnerability layer protection, also thwarts Aurora., we're told. F-Secure's software was among the many products not tested by NSS.
