  • Total Topics: 16978
  • Online today: 137655
Guests: 134645
Total: 134647
Author Topic: Norton Power Eraser (download)  (Read 11358 times)
« on: 19. April 2010., 18:39:51 »
Norton Power Eraser, eliminates difficult to remove crimeware that traditional virus scanning doesn't always detect.
The NEW Norton Power Eraser takes on difficult to detect crimeware known as "scareware" or "rogueware" that cybercriminals use to trick you into unknowingly downloading threats onto your PC. This growing form of crimeware uses bogus pop-up alerts or security messages that scare you into thinking your PC has been infected and needs to be fixed immediately. It can be so tricky that it automatically downloads onto your PC even if you didn’t actively click on anything! The Norton Power Eraser is specially designed to aggressively target and eliminate this type of crimeware and restore your PC back to health.
You should use Power Eraser only when nothing else will remove the threat and you are willing to accept the risk that the scanner may quarantine a legitimate program.
If you have become the victim of crimeware that regular virus scans can’t detect, use the Norton Power Eraser to target and eliminate them.
Download Instructions:
   1. Click on the "Download Norton Power Eraser" button above.
   2. A dialog will appear, click on "Save File".
   3. Select the location where you want to save the file, and click "save".
   4. Go to the location you saved the file and run the file you downloaded.
   5. You may get a prompt asking you to confirm that you want to run the file. Please confirm and continue with the download process.
Download: http://security.symantec.com/nbrt/npe.asp?ssdcat=221&lcid=1033&serviceid=181&pName=NAV&pversion=18.0&origin=thankyou&env=beta&layout=esd&tooltype=both&osver=5.1
Mirror Download: http://liveupdate.symantec.com/upgrade/NMR/English/NMRUI.exe
*Because the Norton Power Eraser uses aggressive methods to detect these threats, there is a risk that it can select some legitimate programs for removal. You should use this tool very carefully, and only after you have exhausted other options.
