  • Total Topics: 16880
  • Online today: 111725
Guests: 97936
Total: 97938
Author Topic: New Hiren's BootCD v.10.5 (download)  (Read 21060 times)
« on: 05. June 2010., 19:01:34 »
New Hiren's BootCD 10.5 is out !!!
All in One Bootable CD which has all these utilities
Antivirus Tools
ComboFix (0306) Designed to cleanup malware infections and restore settings modified by malware
CWShredder 2.19 Popular CoolWebSearch Trojan Remover tool
Dr.Web CureIt! Antivirus (0306) a free standalone anti-virus and anti-spyware on-demand scanner
GMER 1.0.15 Hidden services, hidden registry, hidden file scanner, Rootkit Detector and Remover
Malwarebytes' Anti-Malware 1.46 (0306) anti-malware application that can thoroughly remove even the most advanced malware.
RootkitRevealer 1.7.1 Rootkit Revealer is an advanced patent-pending root kit detection utility.
SmitFraudFix 2.424 This removes Some of the popular Desktop Hijack malware
Spybot - Search & Destroy 1.6.2 (0306) Application to scan for spyware, adware, hijackers and other malicious software.
SpywareBlaster 4.3 (0306) Prevent the installation of spyware and other potentially unwanted software.
SuperAntispyware 4.38.1004 (0306) Remove Malware, Rootkits, Spyware, Adware, Worms, Parasites (a must have tool)
Backup Tools
G4L Ghost 4 Linux 0.33a a hard disk and partition imaging and cloning tool similar to Norton Ghost
Partition Image - PartImage 0.6.9 supported filesystem includes Ext2, Ext3, Reiserfs, HFS, HPFS, JFS, Xfs, UFS, Fat16, Fat32 and NTFS.
COPYR.DMA Build013 A Tool for making copies of hard disks with bad sectors
Double Driver 3.0 Driver Backup and Restore tool
DriverBackup! 1.0.3 Another handy tool to backup drivers
DriveImageXML 2.13 backup any drive/partition to an image file, even if the drive is currently in use
FastCopy 2.01 The Fastest Copy/Delete Software on Windows
GImageX 2.0.17 ImageX is used to backup/restore WIM images for Windows XP/Vista and Windows 7
InfraRecorder 0.50 An Open source CD/DVD burning software, also create/burn .iso images
Partition Saving 3.80 A tool to backup/restore partitions. (SavePart.exe)
RegBak 1.0 a light-weight and simple utility to create backups of Windows registry files
SelfImage 1.2.1.92 to create image files of any mounted or unmounted hard disk partition.
Smart Driver Backup 2.12 Easy backup of your Windows device drivers (also works from PE)
WhitSoft File Splitter 4.5a a Small File Split-Join Tool
Drive SnapShot 1.40 creates an exact Disk Image of your system into a file while windows is running.
Acronis True Image 8.1.945 Create an exact disk image for complete system backup and disk cloning.
Drive Image 2002 Best software to clone hard drive for Windows 98/2000/XP
Norton Ghost 11.5.1 Similar to Drive Image (with Image Explorer and usb/scsi support)
BIOS / CMOS Tools
Award DMI Configuration Utility 2.43 DMI Configuration utility for modifying/viewing the MIDF contents.
!BIOS 3.20 a powerfull utility for bios and cmos
BIOS Cracker 5.0 BIOS password remover (cmospwd)
BIOS Utility 1.35.0 BIOS Informations, password, beep codes and more.
CMOS 0.93 CMOS Save / Restore Tool
DISKMAN4 a powerful all in one utility
Kill CMOS a tiny utility to wipe cmos
UniFlash 1.40 bios flash utility
Browsers / File Managers
7-Zip 9.13b File Manager/Archiver Supports 7z, ZIP, GZIP, BZIP2, TAR, RAR, CAB, ISO, ARJ, LZH, CHM, MSI, WIM, Z, CPIO, RPM, DEB and NSIS formats
Explore2fs 1.08b GUI explorer tool for accessing linux ext2 and ext3 filesystems under windows
Opera Web Browser 8.54 One of the fastest, smallest and smartest full-featured web browser
Total Commander 7.50a A file manager similar to the Windows Explorer features side-by-side file-browsing panes, built-in FTP, archive management, file search/compare/synchronize and more.
Dos Command Center 5.1 Classic dos-based file manager.
Dos Navigator 6.4.0 Dos File Manager, Norton Commander clone but has much more features.
File Maven 3.5 an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable
File Wizard 1.35 a file manager - colored files, drag and drop copy, move, delete etc.
FastLynx 2.0 Dos file manager with Pc to Pc file transfer capability
Volkov Commander 4.99 Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander)
Mini Windows 98 Can run from Ram Drive, with ntfs support, 7-Zip, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Mini Windows Xp Portable Windows Xp that runs from CD/USB/Ram Drive, with Network and SATA support
Cleaners
CCleaner 2.32.1165 Crap Cleaner is a freeware system optimization and privacy tool
CleanUp! 4.5.2 Removes junk files from all user profiles that accumulate over time and litter your hard drive
Data Shredder 1.0 A tool to Erase disk and files (also wipe free space) securely
SpaceMonger 1.4 keeping track of the free space on your computer
WinDirStat 1.1.2.80 a disk usage statistics viewer and cleanup tool for Windows.
FileSystems Tools
AlternateStreamView 1.12 View/Copy/Delete hidden NTFS Alternate Data Streams
FileDisk Mount Tool 25 to mount ISO/BIN/NRG/MDF/IMA images on windows.
NewSID 4.10 utility that changes the security ID (SID) for Windows NT, 2000 and XP
NTFS Access 2.1 Set NTFS permissions recursively and full access rights to a folder/file owner
Virtual Floppy Drive 2.1 enables you to create and mount a virtual floppy drive on your NT/2000/XP/Vista
EditBINI 1.01 to Edit boot.ini on NTFS Partition
NTFS4Dos 1.9 To access ntfs partitions from Dos
NTFS Dos 3.02 To access ntfs partitions from Dos
NTFS Dos Pro 5.0 To access ntfs partitions from Dos
Paragon Mount Everything 3.0 To access NTFS, Ext2FS, Ext3FS partitions from dos
Hard Disk Tools
Active Kill Disk 4.1.2393 Securely overwrites and destroys all data on physical drive.
ExcelStor's ESTest 4.50 ExcelStor hard disk diagnostic utility
Fujitsu HDD Diagnostic Tool 7.00 to check IDE drives for possible defects/problems
Fujitsu IDE Low Level Format 1.0 Low Level Format Tool
Gateway GwScan 5.12 Gateway hard drive diagnostic utility
Hard Disk Sentinel 1.00.5 Hard Disk health, performance and temperature monitoring tool.
HDAT2 4.53 main function is testing and repair (regenerates) bad sectors for detected devices
HDD Erase 4.0 Secure erase using a special feature built into most newer hard drives
IBM Hitachi Drive Fitness Test 4.16 quickly and reliably tests SCSI, IDE and SATA drives
IBM Hitachi Feature Tool 2.15 allows you to control some of the features of the the HDD
Maxtor amset utility 4.0 Utility for changing Acoustic Management on the hard drives
Maxtor Low Level Formatter 1.1 Maxtor's Low Level Format Utility works on any harddrive
Maxtor PowerMax 4.23 designed to perform diagnostic read/write verifications on Maxtor/Quantum hard drives
MHDD 4.6 Precise diagnostic of the mechanical part of a drive, perform Low-level format, Bad Sector Sepair, access raw sectors, manage S.M.A.R.T. (SMART) and other drive parameters such as acoustic management, security, Host Protected Area, etc.
Samsung Disk Diagnose (SHDIAG) 1.28 to diagnose the disk when suspected to have failures
Samsung ESTOOL 3.00g Drive Diagnostic, Automatic Acoustic Management, Enable/Disable SMART etc
Samsung HDD Utility(HUTIL) 2.10 The Drive Diagnostic Utility
SeaTools for Dos GUI 2.20 Text 1.10 versions to test Seagate or Maxtor Parallel ATA (PATA and IDE) and Serial ATA (SATA) interface disc drives
SmartUDM 2.00 Hard Disk Drive S.M.A.R.T. Viewer.
Toshiba Hard Disk Diagnostic 2.00b Toshiba hard drive diagnostic utility
Victoria 3.33e and 3.52rus a freeware program for low-level HDD diagnostics
ViVard 1.0 HDD low-level diagnostics, Surface test with remap, SMART-attributes etc.
WDClear 1.30 Restore/Erases the drive back to a factory condition
Western Digital Data Lifeguard Tools 11.2 for the installation of Western Digital EIDE Hard Drives
Western Digital Diagnostics (DLGDIAG) 5.04f to quickly and efficiently verify the status of the drive
Darik's Boot and Nuke (DBAN) 1.0.7 Completely deletes the contents of any hard disk it can detect
HDD Regenerator 1.71 to recover a bad hard drive
BootSect 6.0.6 Boot Sector Manipulation Tool, This tool replaces FixFAT.exe and FixNTFS.exe
DiskMan 4.2 all in one tool for cmos, bios, bootrecord and more
Grub4Dos installer 1.1 an universal boot loader GRUB for DOS installer
MBRWizard 3.0.46 Directly update and modify the MBR (Master Boot Record)
MbrFix 1.3 To backup, restore, fix the boot code in the MBR
MBR Utility 1.05 to manipulate a drive's master boot record (MBR) via the command line
BootFix Utility Run this utility if you get 'Invalid system disk'
Boot Partition 2.60 add Partition in the Windows NT/2000/XP Multi-boot loader
MBRWork 1.08 a utility to perform some common and uncommon MBR functions
MBRTool 2.3.200 backup, verify, restore, edit, refresh, remove, display, re-write...
MBR SAVE / RESTORE 2.1 BootSave and BootRest tools to save / restore MBR
Smart Boot Manager 3.7.1 a multi boot manager
MultiMedia Tools
MpxPlay 1.56 a small Music Player for dos
Picture Viewer 1.94 Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.58 movie viewer for dos, supports many format including divx.
Ms Dos Tools
1394 Firewire Support 1394 Firewire Drivers for Dos
ASUSTeK USB Driver 3 ASUS USB CD-ROM Device Driver Version 1.00
Dos tools Collection of dos utilities extract.exe pkzip.exe pkunzip.exe lha.exe gzip.exe uharcd.exe imgExtrc.exe xcopy.exe diskcopy.com mouse.com undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe lf.exe delpart.exe wipe.com zap.com format.com deltree.exe more.com find.exe hex.exe debug.exe split.exe mem.exe attrib.com sys.com smartdrv.exe xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe guest.exe doskey.exe duse.exe move.exe setver.exe intersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
Interlnk support at COM1/LPT1 To access another computer from COM/LPT port
SCSI Support SCSI Drivers for Dos
SATA Support SATA Driver (gcdrom.sys) and JMicron JMB361 (xcdrom.sys) for Dos
Universal USB Driver 2 Panasonic v2.20 ASPI Manager for USB mass storage
USB CD-Rom Driver 1 Standard usb_cd.sys driver for cd drive
Network Tools
Angry IP Scanner 2.21 Scan IP addresses in any range as well as any their ports
CurrPorts 1.80 displays the list of all currently opened TCP and UDP ports on your computer
Network Password Recovery 1.23 Recover Windows XP/Vista network passwords (Credentials file)
TCPView 2.54 Lists TCP and UDP endpoints, including the Local/Remote addresses of TCP connections
Winsock 2 Fix for 9x to fix corrupted Winsock2 information by poorly written Internet programs
XP TCP/IP Repair 1.0 Repair your Windows XP Winsock and TCP/IP registry errors
Optimizers
Defraggler 1.19 to defrag your entire hard drive or individual files
JkDefrag 3.36 Free disk defragment and optimize utility for Windows 2000/2003/XP/Vista/Windows 7
NT Registry Optimizer 1.1j Registry Optimization for Windows NT/2000/2003/XP/Vista
PageDfrg 2.32 System file Defragmenter For NT/2k/XP
Other Tools
Bulk Rename Utility 2.7.1.1 Rename multiple files, change timestamps and rename using EXIF data with the click of a button.
EasyUHA 1.0 GUI Tool to create and extract UHA Archives
HxD 1.7.7.0 Hex Editor provides tools to inspect and edit files, main memory, disks/disk images
IrfanView 4.27 A free Image Viewer/Editor/Converter and Optimizer
Fix NTLDR is missing Fix "NTLDR is missing, Press any key to restart" for Windows Xp
Universal TCP/IP Network 6.5 MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 98 different network card drivers
Recovery is Possible LinuxRIPLinux contains ddrescue, dump/restore, epdfview, fsarchiver, grub2, hdparm, isomaster, lftp, lynx, lzip, mtpaint, ntfs-3g, openssh, partclone, partimage, pccmoscleaner, pcdiskeraser, pcloginnow, pcregedit, qemu, reiserfsck, safecopy, smbclient, xfburn and more
Partition Tools
GParted Partition Editor 0.5.2 to create, copy, paste, delete, hide, resize or move partitions without losing data
Fat32 Formatter GUI 1.01 Windows XP cannot format a volume bigger than 32GB with FAT32
Partition Wizard Home Edition 5.0 Free Partition Magic Alternative, Partition Resize/Move/Copy/Create/Delete/Format/Convert, Explore, etc.
USB Format Tool Format/make bootable any USB flash drive to FAT, FAT32, or NTFS partition.
eXtended Fdisk 0.9.3 XFDISK allows easy partition creation and edition
Partition Table Editor 8.0 Partition Table and Boot Record Editor
Ranish Partition Manager 2.44 a boot manager and hard disk partitioner.
Smart Fdisk 2.05 a simple harddisk partition manager
SPecial Fdisk 2000.03v SPFDISK a partition tool.
Super Fdisk 1.0 Create, delete, format partitions drives without destroying data.
The Partition Resizer 1.3.4 move and resize your partitions in one step and more.
Acronis Disk Director 10.0.2160 Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1274 Universal tool for partitions
Partition Magic Pro 8.05 to partition hard drive for Windows 98/2000/XP
Password Tools
Asterisk Logger 1.04 Reveal passwords hidden behind asterisk characters.
Content Advisor Password Remover 1.01 It Removes Content Advisor Password from Internet Explorer
LicenseCrawler 0.0.42 find the license keys and serial numbers of your programs
Mail PassView 1.55 Recovers mail passwords of Outlook Express, MS Outlook, IncrediMail, Eudora, etc.
MessenPass 1.30 A password recovery tool that reveals the passwords of several instant messangers
Password Renew 1.1 Utility to (re)set windows passwords
ProduKey 1.40 Recovers lost the product key of your Windows/Office
PST (Outlook) Password Recovery 1.12 Small utility that recovers lost password of Outlook .PST (Personal Folders) file
WindowsGate 1.1 Enables/Disables Windows logon password validation
WinKeyFinder 1.73 Allows you to View and Change Windows XP/2003 Product Keys, backup and restore activation related files, backup Microsoft Office 97, 2000 SP2, XP/2003 keys etc.
WirelessKeyView 1.34 Recovers all wireless network keys (WEP/WPA) stored in your computer by WZC
XP Key Reader 2.7 Can decode the XP-key on Local or Remote systems
Kon-Boot 1.1 to bypass Login Password of Windows (32bit, any password) and Linux (kon-usr)
Offline NT Password Changer 2008-08-02 utility to reset/unlock windows NT/2000/XP/Vista/7 administrator/user password.
ATAPWD 1.2 Hard Disk Password Utility
NTPWD utility to reset windows nt/2000/xp administrator/user password.
Active Password Changer 3.0.420 To Reset User Password on windows NT/2000/XP/2003/Vista (FAT/NTFS)
Process Tools
Dependency Walker 2.2 Checks for missing/invalid DLL/modules/functions for any exe/dll/ocx/sys.
IB Process Manager 1.04 a little process manager for 9x/2k, shows dll info etc.
OpenedFilesView 1.46 View opened/locked files in your system, sharing violation issues
Pocket KillBox 2.0.0.978 can be used to get rid of files that stubbornly refuse to allow you to delete them
Process Explorer 12.03 shows you information about which handles and DLLs processes have opened or loaded
Process Monitor 2.91 to monitor real-time file system, Registry and process/thread activity, This tool replaces Filemon and Regmon
ProcessActivityView 1.11 Detailed process access information read/write/opened files etc
Unlocker 1.8.9 This tool can delete file/folder when you get this message - Cannot delete file: Access is denied, The file is in use by another program etc.
RAM (Memory) Testing Tools
MemTest 1.0 a Memory Testing Tool
Video Memory Stress Test 1.7.116 a tool to thoroughly test your video RAM for errors and faults
Windows Memory Diagnostic a RAM Test tool
Memtest86+ 4.10 PC Memory Test
Recovery Tools
Partition Find and Mount 2.31 Partition Find and Mount software is designed to find lost or deleted partitions
PhotoRec 6.12b Tool to Recover File and pictures from Dos/Windows/Linux
PartitionRecovery 1.0 A freeware tool to recover accidentally deleted partitions
Recuva 1.37.488 Restore deleted files from Hard Drive, Digital Camera Memory Card, usb mp3 player...
Restoration 3.2.13 a tool to recover deleted files
Smart Partition Recovery 3.3 Find Lost NTFS partitions and restore them back.
SoftPerfect File Recovery 1.2 to restore accidentally deleted files from hard drive, USB flash drives, CF and SD memory cards
TestDisk 6.12b Tool to check and undelete partition from Dos/Windows/Linux
Unstoppable Copier 4.4 Allows you to copy files from disks with problems such as bad sectors, scratches or that just give errors when reading data.
Active Undelete 5.5 a tool to recover deleted files
Active Partition Recovery 3.0 To Recover a Deleted partition.
DiyDataRecovery Diskpatch 2.1.100 An excellent data recovery software.
GetDataBack for FAT/NTFS 4.0 Data recovery software for FAT/NTFS file systems
Ontrack Easy Recovery Pro 6.10 To Recover data that has been deleted/virus attack
Prosoft Media Tools 5.0 v1.1.2.64 Another excellent data recovery software with many other options.
Registry Tools
ERUNT 1.1j The Emergency Recovery Utility NT Registry Backup and Restore for Windows NT/2000/2003/XP
Fix HDC Fix the Hard Drive Controller when replacing your motherboard on an XP system
RegFromApp 1.21 Monitors/exports the Registry changes made by the selected application.
Registry Editor PE 0.9c Easy editing of remote registry hives and user profiles
Registry Restore Wizard 1.0.4 Restores a corrupted system registry from Xp System Restore
RegScanner 1.82 Tool to find/search in the Registry of Windows
Registry Viewer 4.2 Registry Viewer/Editor for Win9x/Me/NT/2K/XP
Remote Control Tools
TeamViewer 1.85 Access any remote computer via Internet just like sitting in front of it, even through firewalls.
TightVNC 1.3.10 Cross-platform Remote Desktop Software to view/control remote pc with mouse and keyboard
Security Tools
DiskCryptor 0.8 High speed disk encryption tool to encrypt all disk/partitions, including the system partition encryption support
TrueCrypt 6.3a On-the-fly Linux/Windows disk encryption tool, can create a virtual encrypted disk within a file and mount it as a real disk, can also encrypt an entire HDD/Partition/USB Drive
Startup Tools
Autoruns 9.57 Displays All the entries from startup folder, Run, RunOnce, and other Registry keys, Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications, auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers and much more which helps to remove nasty spyware/adware and viruses.
HijackThis 2.0.4 a general homepage hijackers detector and remover and more
Silent Runners Revision 61 A free script that helps detect spyware, malware and adware in the startup process
Startup Control Panel 2.8 a tool to edit startup programs
Startup Monitor 1.02 it notifies you when any program registers itself to run at system startup
System Information Tools
BlueScreenView 1.26 Scans minidump files for BSOD (blue screen of death) crash information
CPU-Z 1.54 It gathers information on some of the main devices of your system
Drive Temperature 1.0 Hard Disk Drive temperature meter
GPU-Z 0.4.3 A lightweight utility designed to give you all information about your video card and GPU
HDTune 2.55 Hard disk benchmarking and information tool.
PC Wizard 2010.1.94 Powerful system information/benchmark utility designed especially for detection of hardware.
PCI 32 Sniffer 1.4 (0306) device information tool (similar to unknown devices)
SIW 2010-05-12 Gathers detailed information about your system properties and settings.
UnknownDevices 1.4.20 (0306) helps you find what those unknown devices in Device Manager really are
USBDeview 1.70 View/Uninstall all installed/connected USB devices on your system
Astra 5.45 Advanced System info Tool and Reporting Assistant
CPU Identification utility 1.18 Detailed information on CPU (CHKCPU.EXE)
CTIA CPU Information 2.7 another CPU information tool
HWiNFO 5.3.5 a powerful system information utility
Navratil Software System Information 0.60.38 High-end professional system information tool
PCI and AGP info Tool (0306) The PCI System information & Exploration tool.
System Analyser 5.3w View extensive information about your hardware
SysChk 2.46 Find out exactly what is under the hood of your PC
Testing Tools
Disk Speed 1.0 Hard Disk Drive Speed Testing Tool
H2testw 1.4 Check your USB Flash memory cards, internal/external hard drives and network drives for errors with this tool
HDD Scan 3.2 HDDScan is a Low-level HDD diagnostic tool, it scans surface find bad sectors etc.
IsMyLcdOK (Monitor Test) 1.02 Allows you to test CRT/LCD/TFT screens for dead pixels and diffective screens
S&M Stress Test 1.9.1 cpu/hdd/memory benchmarking and information tool, including temperatures/fan speeds/voltages
System Speed Test 4.78 it tests CPU, harddrive, ect.
CPU/Video/Disk Performance Test 5.7 a tool to test cpu, video, and disk
Test Hard Disk Drive 1.0 a tool to test Hard Disk Drive
PC-Check 6.21 Easy to use hardware tests
Tweakers
Dial a Fix 0.60.0.24 Fix errors and problems with COM/ActiveX object errors and missing registry entries, Automatic Updates, SSL, HTTPS, and Cryptography service (signing/verification) issues, Reinstall internet explorer etc. comes with the policy scanner
EzPcFix 1.0.0.16 Helpful tool when trying to remove viruses, spyware, and malware
InstalledCodec 1.15 Disable/Enable Installed Codec drivers and DirectShow filters
RemoveWGA 1.2 Windows Genuine Advantage Notifications Removal tool
RRT - Remove Restrictions Tool 3.0 To Re-enable Ctrl+Alt+Del, Folder Options and Registry tools etc.
Shell Extensions Manager (ShellExView) 1.47 An excellent tool to View and Manage all installed Context-menu/Shell extensions
ShellMenuNew 1.01 View/Change the list of all menu items in the 'New' submenu of Windows Explorer
TweakUI 2.10 This PowerToy gives you access to system settings that are not exposed in Windows Xp
Ultimate Windows Tweaker 2.1 A TweakUI Utility for tweaking and optimizing Windows Vista
Xp-AntiSpy 3.97.9 it tweaks some Windows XP functions, and disables some unneeded Windows services quickly
Source - NewsApp Portal: http://newsapp.info/index.php/topic,3858.0.html
Hiren's Boot cd 10.5 is about 267 MB "big" and as we have information provided by P2P network.
Search for Hiren via Lime Wire or µTorrent:
http://scforum.info/index.php/topic,1469.0.html
luffy
Re: New Hiren's BootCD v.10.5 (download)
« Reply #1 on: 05. June 2010., 20:21:54 »
That's one hell of utilities collection.
« Reply #2 on: 05. June 2010., 21:34:04 »
Yes it's (but illegal).
Because of that We provide only info's at SCF...
einherjar
« Reply #3 on: 06. June 2010., 00:18:52 »
wow, thanks for the info :bih:
you can say that again ;)
haz
« Reply #4 on: 06. June 2010., 06:29:39 »
Admins heaven in one CD :)
Thanks
Delsol
« Reply #5 on: 10. June 2010., 01:40:42 »
The older version(s) of the Hiren bootable CD still rock!! :-)
kn1ghtm4r3
« Reply #6 on: 15. October 2010., 07:40:01 »
love hirens boot cd. makes life so much easier when things go wrong
