  • Total Topics: 15520
  • Online Today: 718
Author Topic: Disabling the Quick Scan that runs after virus definitions update in Symantec  (Read 9259 times)
Disabling the Quick Scan that runs after virus definitions update in Symantec AntiVirus 10.0 and Symantec Client Security 3.0
Article: TECH101323   |  Created: 2005-01-25 10:15 UTC   |  Updated: 2010-08-13 08:05 UTC
Problem
After you update virus definitions, Symantec AntiVirus Corporate Edition 10.0 runs a Defwatch Quick Scan. Symantec AntiVirus quarantines security risks for which you created an exception during this Quick Scan. You need to know how to disable the Defwatch Quick Scan.
Solution
Before you begin: This document applies to Symantec AntiVirus 10.0 and Symantec Client Security 3.0. If you use Symantec AntiVirus 10.1 or Symantec Client Security 3.1, read the following document:
Disabling the Quick Scan that runs after virus definitions update in Symantec AntiVirus 10.1 and Symantec Client Security 3.1
A Quick Scan is a fast scan of the following:
Files loaded into memory
Common virus and security risk loading points, including registry keys and startup files
To disable the Quick Scan that runs after virus definitions update, follow the directions for each type of computer in your environment.
Servers
You can disable the Defwatch Quick Scan by importing a .reg file or by editing the registry. After you make this change, the Quick Scan still runs after virus definitions update, but the Quick Scan does not scan any files.
To disable the Defwatch Quick Scan by importing a .reg file
Download and import the DefwatchQSOff.reg file.
To disable the Defwatch Quick Scan by editing the registry
On the Windows taskbar, click Start > Run.
In the Open box, type the following text:
regedit
Click OK.
In the left pane of the Registry Editor, go to the following key:
HKEY_LOCAL_MACHINE\Software\Intel\Landesk\VirusProtect6\CurrentVersion\LocalScans\Defwatch QuickScan Options
In the right pane, double-click the ScanBootSector value.
Change the Value data field to 0, and then click OK.
In the right pane, double-click the ScanLoadPoints value.
In the right pane, double-click the ScanProcesses value.
Exit the Registry Editor.
Managed clients
You can disable the Defwatch Quick Scan on all managed clients by editing the registry on the parent server. After you make this change, the Quick Scan still runs after virus definitions update, but the Quick Scan does not scan any files.
To disable the Defwatch Quick Scan by editing the registry on the parent server
regedit
Click OK.
HKEY_LOCAL_MACHINE\Software\Intel\Landesk\VirusProtect6\CurrentVersion\ClientConfig\LocalScans
Right-click the LocalScans key, and then click New > Key.
Type the following name for the key:
Right-click the Defwatch QuickScan Options key, and then click New > DWORD Value.
ScanBootSector
ScanLoadPoints
ScanProcesses
If you use client groups, go to the following key:
HKEY_LOCAL_MACHINE\Software\Intel\LANDesk\VirusProtect6\CurrentVersion\Groups\<GroupName>\ClientConfig\LocalScans
where <GroupName> is the name of a client group.
Repeat steps 5–17, and then continue to step 20.
Repeat steps 18 and 19 for each client group.
Start Symantec System Center, and unlock the server group.
Right-click the parent server, and then click All Tasks > Symantec AntiVirus > Client Auto-Protect Options.
Click Reset All, and then click OK.
Unmanaged clients
regedit
Click OK.
Technical Information
The Defwatch Quick Scan does not use the exclusions or exceptions that are set for the Default Quick Scan, which runs when the computer starts. You cannot configure the DefWatch Quick Scan by using Symantec System Center or in the Symantec AntiVirus program interface.
In Symantec AntiVirus 10.1 and later, you can turn off the Deftwach Quick Scan for managed clients by using Symantec System Center.
/apps/media/inquira/resources /resources
Value
Defect #1-4BQOJP
Article URL http://www.symantec.com/docs/TECH101323
________________________________________________________________________________________
Article: TECH101761   |  Created: 2006-01-23 10:18 UTC   |  Updated: 2007-01-20 07:49 UTC
Problem
After you update virus definitions, Symantec AntiVirus Corporate Edition 10.1 runs a Defwatch Quick Scan. You need to know how to disable the Defwatch Quick Scan.
Solution
Before you begin: This document applies to Symantec AntiVirus 10.1 and Symantec Client Security 3.1. If your clients or servers run Symantec AntiVirus 10.0 or Symantec Client Security 3.0, read the following document:
Managed clients
You can disable the Quick Scan that runs after virus definitions update by changing a setting in Symantec System Center.
To disable the Defwatch Quick Scan on managed clients
Start Symantec System Center.
Unlock the server group.
Right-click a server group, a client group, or a server, and then click All Tasks> Symantec AntiVirus> Client Administrator Only Options.
On the Scans tab, under Triggered Scans, uncheck Run a Quick Scan when new definitions arrive.
Click OK.
Note: If Symantec AntiVirus quarantines security risks for which you created an exception during this Quick Scan, make sure that you add the security risk to the global exclusions list.
For directions, read Configuring global security risk exclusions in Symantec AntiVirus 10.1 and Symantec Client Security 3.1.
Servers
On Symantec AntiVirus 10.1 servers, the Defwatch Quick Scan is disabled by default. You can disable or enable the Defwatch Quick Scan by editing the registry.
To disable or enable the Defwatch Quick Scan by editing the registry
On the Windows taskbar, click Start> Run.
regedit
Click OK.
HKEY_LOCAL_MACHINE\Software\Intel\Landesk\VirusProtect6\CurrentVersion\AdministratorOnly\General
In the right pane, double-click the EnableDefwatchQuickscan value.
Do one of the following:
To disable the Defwatch Quick Scan, change the Value data field to 0, and then click OK.
To enable the Defwatch Quick Scan, change the Value data field to 1, and then click OK.
Unmanaged clients
You can disable the Defwatch Quick Scan by editing the registry.
regedit
Click OK.
Article URL http://www.symantec.com/docs/TECH101761
Compstuff
GREAT post!!!!
