  • Total Topics: 16942
  • Online today: 137698
Guests: 132493
Total: 132496
Author Topic: Problem with Mcafee 8.7 with Patch 4, mcshield.exe crash, framework service...  (Read 7756 times)
vishwanath99
smaker i don't know where i ask this qus..
if i install 8.7 in any P4 system. It almost hang out what is the problem
Mcshield.exe crash and Framework service wl take high cpu usage
According to you what is system requirement for 8.7i..
buffer - overflow  doesn't work in win7 and vista
Is it problem of other AV entries in registry.. I checked after uninstalling NOD and some other AV their entries in registry and in system wl not completely removed
Hi vishwanath99, did I understand you correctly... after you applied Patch 4 you experience problems with: Mcshield.exe, Framework service... ??
P.S.
I was split your post from "Artemis topic" and make new one here (SCF's "PC Help Center"), because of other visitors which maybe have similar problems... ;)
testuser
Are you using the patch 4 or the patch 4 repost?
