  • Total Topics: 17012
  • Online today: 22617
Guests: 22191
Total: 22194
Author Topic: Computer froze up after McAfee scan  (Read 18187 times)
cplcody
« on: 20. December 2010., 03:39:01 »
Please someone help.
I started a scan with Mcaffee and computer froze up.
OS is xp w/ service pack 3. on restart screen just has flashing cursor at top left hand corner. Will not boot in safemode, have to use reinstall disk but still same results after running it
Re: Computer froze up after McAfee scan
« Reply #1 on: 20. December 2010., 05:53:32 »
Hi cplcody, I'll try to help you...
First of all, I need to know did you formatted your HD or not?? I'm not sure about that after your explanation. (I'm not so good with English... :-[ )
If not, I need information did you success to run XP in any way and did you receive any error/notification during scanning process??
P.S.
Please check this Topic also, maybe your problem in some way is related to this issue:
http://scforum.info/index.php/topic,4099.0.html
cplcody
« Reply #2 on: 20. December 2010., 06:11:10 »
Thanks for replying. I do not believe the reformat was sucessfull. I saw where it erased files then added files but the machine still does not  boot in any way
cplcody
« Reply #3 on: 20. December 2010., 06:12:53 »
was not able to see if the scan found anything or not.
« Reply #4 on: 20. December 2010., 06:30:21 »
hmmm... very strange.  ???
Anyway since you're try to format your HDD there is no point to speak about McAfee anymore?? Right now We have problem with your HDD, formation and installation of new OS - XP.
Do you have possibility to add that HDD to some other PC like second HDD and format them there?
cplcody
« Reply #5 on: 20. December 2010., 10:06:16 »
I have old dell dimension tht shared files with the comp thru network. must be honest,
I am not comp tech savy at all, barely set up a network.
how to format hdd and install xp (instructions)
« Reply #6 on: 20. December 2010., 12:44:35 »
Yes I understand... did you maybe have original installation CD for XP??
If you do, simply follow these instruction for format and XP installation: http://support.microsoft.com/kb/313348
Hope this will help you??
cplcody
« Reply #7 on: 20. December 2010., 13:37:44 »
I forgot to mention that my son left a Beatle's CD in the rom drive. When Mcafee started to scan that could that have caused all this?  I have a lot of pics that Id would like to save. Possible?
« Reply #8 on: 20. December 2010., 14:53:26 »
I don't think that there is some possibility to save anything since you already start formatting... and your PC still doesn't boot??
Lets we try to release CD Rom...
Turn the pc off. Use a paper clip that you've straightened out and insert it into the tiny little hole on the drive to manually open the drawer.
After that, try new installation (or maybe first try to repair XP) with XP installation CD.
Instructions for repair: http://www.michaelstevenstech.com/XPrepairinstall.htm
cplcody
« Reply #9 on: 21. December 2010., 03:50:38 »
Thank u for the help. I sucessfully formatted hd and reinstalled xp but lost many photos  :(
