hi..sorry for the delay.. the power was cut off due to "rotational power cutoff" in our place
the reason wanted to run msconfig is to disable some unnecessary programs that automatically load on start up..
--i have read some sources that i can do that using msconfig(so i tried to run msconfig and then error dialog says windows cannot find msconfig)
my computer specs
ms windows xp prof sp3 32-bit
processor: intel core 2 duo cpu E4500 @2.2GHz
1.00GB ram
radeon x1550 series (video card)
antivirus: mcafee vse 8.5i w/ the latest patch
i also installed tune up utilities 2011
ok here is my panda result(im shocked i have 4 infected files) i copied the result txt.
ANALYSIS: 2010-12-24 21:39:56
PROTECTIONS: 1
MALWARE: 4
SUSPECTS: 0
PROTECTIONS
Description Version Active Updated
McAfee VirusScan Enterprise 8.5.0.781 Yes Yes
MALWARE
Id Description Type Active Severity Disinfectable Disinfected Location
00139061 Cookie/Doubleclick TrackingCookie No 0 Yes No c:\documents and settings\administrator\cookies\administrator@doubleclick[1].txt
00168056 Cookie/YieldManager TrackingCookie No 0 Yes No c:\documents and settings\administrator\cookies\administrator@ad.yieldmanager[1].txt
00170554 Cookie/Overture TrackingCookie No 0 Yes No c:\documents and settings\administrator\cookies\administrator@overture[1].txt
00172221 Cookie/Zedo TrackingCookie No 0 Yes No c:\documents and settings\administrator\cookies\administrator@zedo[2].txt
SUSPECTS
Sent Location
VULNERABILITIES
Id Severity Description
223917 HIGH MS10-084
223916 HIGH MS10-083
223914 HIGH MS10-081
223909 HIGH MS10-076
223906 HIGH MS10-073
223904 HIGH MS10-071
223355 HIGH MS10-069
223353 HIGH MS10-067
223352 HIGH MS10-066
223349 HIGH MS10-063
223346 HIGH MS10-061
222627 HIGH MS10-054
222626 HIGH MS10-053
222622 HIGH MS10-049
222621 HIGH MS10-048
222620 HIGH MS10-047
222470 HIGH MS10-046
222062 HIGH MS10-042
221290 HIGH MS10-035
221289 HIGH MS10-034
221287 HIGH MS10-032
219830 HIGH MS10-029
219822 HIGH MS10-021
219821 HIGH MS10-020
219647 HIGH MS10-018
217842 HIGH MS10-015
217839 HIGH MS10-012
217838 HIGH MS10-011
217834 HIGH MS10-008
217832 HIGH MS10-006
217831 HIGH MS10-005
217169 HIGH MS10-002
216839 HIGH MS10-001
215938 HIGH MS09-072
215935 HIGH MS09-069
215048 HIGH MS09-065
214076 HIGH MS09-059
214075 HIGH MS09-058
214074 HIGH MS09-057
214073 HIGH MS09-056
214072 HIGH MS09-055
214071 HIGH MS09-054
213109 HIGH MS09-046
here is my hijackthis result i also copy the txt (i click scan and save log file)
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 11:40:01 PM, on 12/24/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.exe
C:\Program Files\McAfee\VirusScan Enterprise\SHSTAT.EXE
C:\Program Files\McAfee\Common Framework\UdaterUI.exe
C:\Program Files\McAfee\Common Framework\McTray.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\McAfee\Common Framework\FrameworkService.exe
C:\Program Files\McAfee\VirusScan Enterprise\Mcshield.exe
C:\Program Files\McAfee\VirusScan Enterprise\VsTskMgr.exe
C:\Program Files\CyberLink\Shared Files\RichVideo.exe
C:\Program Files\TuneUp Utilities 2011\TuneUpUtilitiesService32.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\TuneUp Utilities 2011\TuneUpUtilitiesApp32.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Documents and Settings\Administrator\Desktop\Internet Downloads\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
http://www.yahoo.com/?fr=fp-yie8R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar =
http://search.bearshare.com/sidebar.html?src=ssbR0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
http://www.yahoomail.com/R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
http://go.microsoft.com/fwlink/?LinkId=69157R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
http://go.microsoft.com/fwlink/?LinkId=54896R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar =
http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr8/*http://www.yahoo.com/ext/search/search.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
http://go.microsoft.com/fwlink/?LinkId=54896R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page =
http://go.microsoft.com/fwlink/?LinkId=69157R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) =
http://aa.rd.yahoo.com/customize/ie/defaults/su/msgr9/*http://ph.yahoo.com
R3 - URLSearchHook: Alawar.com Toolbar - {511131f1-4629-4254-a85f-ed7b6d75dd3c} - C:\Program Files\Alawar.com\tbAla2.dll
R3 - URLSearchHook: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc} - C:\Program Files\uTorrentBar\tbuTor.dll
F2 - REG:system.ini: Shell=Explorer.exe msnmgnr.exe
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe,userinit.exe
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Conduit Engine - {30F9B915-B755-4826-820B-08FBA6BD249D} - C:\Program Files\ConduitEngine\ConduitEngine.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - (no file)
O2 - BHO: Alawar.com Toolbar - {511131f1-4629-4254-a85f-ed7b6d75dd3c} - C:\Program Files\Alawar.com\tbAla2.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan Enterprise\Scriptcl.dll
O2 - BHO: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc} - C:\Program Files\uTorrentBar\tbuTor.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Alawar.com Toolbar - {511131f1-4629-4254-a85f-ed7b6d75dd3c} - C:\Program Files\Alawar.com\tbAla2.dll
O3 - Toolbar: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc} - C:\Program Files\uTorrentBar\tbuTor.dll
O4 - HKLM\..\Run: [ShStatEXE] "C:\Program Files\McAfee\VirusScan Enterprise\SHSTAT.EXE" /STANDALONE
O4 - HKLM\..\Run: [McAfeeUpdaterUI] "C:\Program Files\McAfee\Common Framework\UdaterUI.exe" /StartedFromRunKey
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\Administrator\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - HKCU\..\Run: [uTorrent] "C:\Program Files\uTorrent\uTorrent.exe"
O4 - HKLM\..\Policies\Explorer\Run: [csrcs] C:\WINDOWS\system32\csrcs.exe
O4 - HKUS\S-1-5-18\..\Run: [Nokia.PCSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [Nokia.PCSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog (User 'Default user')
O8 - Extra context menu item: &Search -
http://edits.mywebsearch.com/toolbaredits/menusearch.jhtml?p=ZRman000O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {48884C41-EFAC-433D-958A-9FADAC41408E} (EGamesPlugin Class) -
https://www.e-games.com.ph/com/EGamesPlugin.cabO16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) -
http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cabO16 - DPF: {9191F686-7F0A-441D-8A98-2FE3AC1BD913} (ActiveScan 2.0 Installer Class) -
http://acs.pandasoftware.com/activescan/cabs/as2stubie.cabO16 - DPF: {D6FCA8ED-4715-43DE-9BD2-2789778A5B09} (NPKCX Control) -
https://my.levelupgames.ph/keycrypt/npkcx.cabO16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} -
http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cabO20 - Winlogon Notify: Antiwpa - antiwpa.dll (file missing)
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: McAfee Framework Service (McAfeeFramework) - McAfee, Inc. - C:\Program Files\McAfee\Common Framework\FrameworkService.exe
O23 - Service: McAfee McShield (McShield) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan Enterprise\Mcshield.exe
O23 - Service: McAfee Task Manager (McTaskManager) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan Enterprise\VsTskMgr.exe
O23 - Service: NMIndexingService - Unknown owner - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe (file missing)
O23 - Service: nProtect GameGuard Service (npggsvc) - Unknown owner - C:\WINDOWS\system32\GameMon.des.exe (file missing)
O23 - Service: npkcsvc - INCA Internet Co., Ltd. - C:\WINDOWS\system32\npkcsvc.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: TuneUp Utilities Service (TuneUp.UtilitiesSvc) - TuneUp Software - C:\Program Files\TuneUp Utilities 2011\TuneUpUtilitiesService32.exe
End of file - 8850 bytes
did i do right?
anyways tanx for the help in advance
