  • Total Topics: 17051
  • Online today: 9346
Guests: 9180
Total: 9183
Author Topic: Hiren's BootCD 13.0  (Read 7840 times)
Hiren's BootCD 13.0
« on: 03. January 2011., 21:50:36 »
Antivirus Tools
Avira AntiVir Personal (31-12-2010)
Free anti-virus and anti-spyware on-demand scanner, detects and removes more than 50000 viruses.
ComboFix (31-12-2010)
Designed to cleanup malware infections and restore settings modified by malware.
CWShredder 2.19
Popular CoolWebSearch Trojan Remover tool.
Dr.Web CureIt! Antivirus (31-12-2010)
a free standalone anti-virus and anti-spyware on-demand scanner.
GMER 1.0.15
Hidden services, hidden registry, hidden file scanner, Rootkit Detector and Remover.
Malwarebytes Anti-Malware 1.50.1 (31-12-2010)
anti-malware application that can thoroughly remove even the most advanced malware.
Remove Fake Antivirus 1.72
a tool to remove virus/malwares which disguises itself to be an antivirus and produces fake alert/warnings and urge you to purchase a useless copy of the fake antivirus.
RootkitRevealer 1.7.1
Rootkit Revealer is an advanced patent-pending root kit detection utility.
SmitFraudFix 2.424
This removes Some of the popular Desktop Hijack malware.
Spybot - Search & Destroy 1.6.2 (31-12-2010)
Application to scan for spyware, adware, hijackers and other malicious software.
SpywareBlaster 4.4 (31-12-2010)
Prevent the installation of spyware and other potentially unwanted software.
SuperAntispyware 4.47.1000 (31-12-2010)
Remove Malware, Rootkits, Spyware, Adware, Worms, Parasites (a must have tool).
Backup Tools
COPYR.DMA Build013
A Tool for making copies of hard disks with bad sectors.
CopyWipe 1.14
Copy old hard drive to a new hard drive by copying the entire contents of one drive to another, CopyWipe can also help prevent confidential or private data from being recovered, by securely wiping the contents of a drive.
DiskImage 1.6
Creates and writes disk images files to hard and floppy disks.
Double Driver 3.0
Driver Backup and Restore tool.
DriveImage XML 2.20
backup any drive/partition to an image file, even if the drive is currently in use, a very good freeware alternative to Ghost / Acronis
DriverBackup! 1.0.3
Another handy tool to backup drivers.
Drive SnapShot 1.40
creates an exact Disk Image of your system into a file while windows is running.
FastCopy 2.06
The Fastest Copy/Delete Software on Windows.
G4L Ghost 4 Linux 0.34a
a hard disk and partition imaging and cloning tool similar to Norton Ghost.
GImageX 2.0.17
ImageX is used to backup/restore WIM images for Windows XP/Vista and Windows 7.
ImgBurn 2.5.2.0
Lightweight CD/DVD/HD DVD/Blu-ray burning application, supports BIN, CUE, DI, DVD, GI, IMG, ISO, MDS, NRG and PDI, Ability to build DVD/HD/BD Video discs from a VIDEO_TS/HVDVD_TS/BDAV/BDMV folder, Unicode folder/file names (formerly DVD Decrypter).
InfraRecorder 0.51
An Open source CD/DVD burning software, also create/burn .iso images.
Macrium Reflect 4.2.2952
Create complete backups of your disk partitions, including operating system, installed programs and all your settings.
Partition Image - PartImage 0.6.9
supported filesystem includes Ext2, Ext3, Reiserfs, HFS, HPFS, JFS, Xfs, UFS, Fat16, Fat32 and NTFS.
Partition Saving 3.90
A tool to backup/restore partitions (SavePart.exe).
RegBak 1.0
a light-weight and simple utility to create backups of Windows registry files.
Raw Copy 1.2
Useful tool to transfer the data directly from a faulty drive to another drive, built in data recovery function which will also attempt to recover data from bad sectors.
ShadowCopy 1.00
Copy all your files and entire system - even if they are locked by Windows.
SelfImage 1.2.1.92
to create image files of any mounted or unmounted hard disk partition.
Seagate DiscWizard 11.8326
Backup drive/partition to an image file, for Seagate owners (Powered by Acronis TrueImage)
Smart Driver Backup 2.12
Easy backup of your Windows device drivers (also works from PE).
WhitSoft File Splitter 4.5a
a Small File Split / Join Tool.
XXClone 0.58.0
The simple way to clone a Windows disk to another disk, it makes a self-bootable clone of Windows system disk.
BIOS / CMOS Tools
Award DMI Configuration Utility 2.43
DMI Configuration utility for modifying/viewing the MIDF contents.
!BIOS 3.20
a powerfull utility for bios and cmos.
BIOS Cracker 5.0
BIOS password remover (cmospwd).
BIOS Utility 1.35.0
BIOS Informations, password, beep codes and more.
CMOS 0.93
CMOS Save / Restore Tool.
DISKMAN4
a powerful all in one utility.
Kill CMOS
a tiny utility to wipe cmos.
UniFlash 1.40
bios flash utility.
Browsers / File Managers
7-Zip 9.20
File archiver with a high compression ratio Supports 7z, ARJ, BZIP2, CAB, CHM, CPIO, DEB, DMG, FAT, GZ, GZIP, HFS, IMA, IMG, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, RAR, RPM, TAR, UDF, VHD, WIM, XAR, XZ, ZIP and Z formats.
Bulk Rename Utility 2.7.1.2
Rename multiple files, change timestamps and rename using EXIF data with the click of a button.
Dos Command Center 5.1
Classic dos-based file manager.
Dos Navigator 6.4.0
Dos File Manager, Norton Commander clone but has much more features.
EasyUHA 1.1
GUI Tool to create and extract UHA Archives.
Everything 1.21
Ultra fast file/folder search tool with ftp/http server.
Explore2fs 1.08b
GUI explorer tool for accessing linux ext2 and ext3 filesystems under windows.
Ext2Explore 2.2.71
To explore ext2/ext3/ext4 disk/partition, can also be used to view and copy disk and file system images.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability.
HashMyFiles 1.68
Calculate MD5/SHA1/CRC32 hashes of your files.
Mini Windows 98
Can run from Ram Drive, with ntfs support, 7-Zip, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc.
Mini Windows Xp
Portable Windows Xp that runs from CD/USB/Ram Drive to repair/recover dead windows operating system. It has LAN and WLAN (Wireless) Network includes 300 WiFi/Ethernet card drivers and can also be customized easily to add your own drivers in HBCD\Drivers folder. Added some USB 3.0 and SATA Storage drivers and VBS/WSH scripting support. Supported keyboard layouts are: United States, United Kingdom, Turkish Q, Turkish F, Swiss German, Swiss French, Swedish, Suomi Finnish, Spanish, Slovenian, Slovak, Russian, Portuguese, Polish, Norvegian Norske, Netherlands Dutch, Latin American, Italy, Icelandic, Hungarian, Hebrew, Germany, German Switzerland Luxembourg, Francais Cavier AZERTY, Denmark Daenish, Bulgarian Phonetic, Bulgarian, Brazil Portuguese, Brazil Extended Portuguese and Belgium.
Opera Web Browser 9.64
One of the fastest, smallest and smartest full-featured web browser.
SearchMyFiles 1.61
Alternative to 'Search For Files And Folders' module of Windows + Duplicates Search.
Total Commander 7.56a
A file manager similar to the Windows Explorer features side-by-side file-browsing panes, built-in FTP, archive management, file search/compare/synchronize and more.
Volkov Commander 4.99
Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander).
WinMerge 2.12.4.0
Differencing and merging tool which can compare both folders and files, presenting differences in a visual text format that is easy to understand and handle.
Cleaners
ATF Cleaner 3.0.0.2
A personal and easy-to-use temp file removal software to clean all user temp folders, Java cache, Opera/Mozilla browser cache, cookies, history, download history, saved passwords etc.
CCleaner 3.02.1343
Crap Cleaner is a freeware system optimization and privacy tool.
CleanUp! 4.5.2
Removes junk files from all user profiles that accumulate over time and litter your hard drive.
CloneSpy 2.52
Duplicate file cleanup tool, can optionaly create hardlinks to save space.
Data Shredder 1.0
A tool to Erase disk and files (also wipe free space) securely.
Delete Doctor 2.2
Delete Files that are hard to delete, Option to delete on reboot or via UNC Name.
Duplicate File Finder 3.5
Scans and identify duplicate files, it compares them based on byte for byte comparison ensures 100% accuracy.
MyUninstaller 1.70
Alternative to the standard add / remove control panel module.
Revo Uninstaller 1.90
Remove unnecessary files and registry entries left behind by incomplete program uninstallation routines.
SpaceMonger 1.4
keeping track of the free space on your computer.
SpaceSniffer 1.1.2.0
Find lost space on your disks the easy way.
WinDirStat 1.1.2.80
a disk usage statistics viewer and cleanup tool for Windows.
Editors / Viewers
HxD 1.7.7.0
Hex Editor provides tools to inspect and edit files, main memory, disks/disk images.
IrfanView 4.28
A free Image Viewer/Editor/Converter and Optimizer.
Picture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.58
movie viewer for dos, supports many format including divx.
SumatraPDF 1.1
a free, open source, lightweight PDF Reader for Microsoft Windows.
FileSystems Tools
AlternateStreamView 1.15
View/Copy/Delete hidden NTFS Alternate Data Streams.
EditBINI 1.01
to Edit boot.ini on NTFS Partition.
FileDisk Mount Tool 25
to mount ISO/BIN/NRG/MDF/IMA/IMG images on windows.
Filemon 7.04
Monitors and displays file system activity on a system in real-time.
NewSID 4.10
utility that changes the security ID (SID) for Windows NT, 2000 and XP.
NTFS Access 2.1
Set NTFS permissions recursively and full access rights to a folder/file owner.
NTFS Dos 3.02
to read-only access ntfs partitions from Dos.
NTFS4Dos 1.9
to read and write ntfs partitions from Dos.
Virtual Floppy Drive 2.1
enables you to create and mount a virtual floppy drive on your NT/2000/XP/Vista.
Hard Disk Tools
Active Kill Disk 4.1.2393
Securely overwrites and destroys all data on physical drive.
Darik's Boot and Nuke (DBAN) 1.0.7
Completely deletes the contents of any hard disk it can detect.
DiskView 2.4
to view graphical map of your disk, allowing you to check where a file is located or, by clicking on a cluster, seeing which file occupies it.
DiskWipe 1.2
Securely erases the contents of a disk replacing it with random data or leaving the drive completely blank.
ExcelStor's ESTest 4.50
ExcelStor hard disk diagnostic utility.
Fujitsu HDD Diagnostic Tool 7.00
to check IDE drives for possible defects/problems.
Fujitsu IDE Low Level Format 1.0
Low Level Format Tool for Fujitsu Drives.
Gateway GwScan 5.12
Gateway hard drive diagnostic utility.
Hard Disk Sentinel 1.00.5
Hard Disk health, performance and temperature monitoring tool.
HDAT2 4.53
the main function is testing and repair (regenerates) bad sectors for detected devices. A freeware alternative of HDD Regenerator.
HDD Low Level Format Tool 2.36
Low-level format tool for S-ATA (SATA), IDE (E-IDE), SCSI, USB, Flash Cards and FIREWIRE external drive enclosures.
HDD Erase 4.0
Secure erase using a special feature built into most newer hard drives.
IBM Hitachi Drive Fitness Test 4.16
quickly and reliably tests SCSI, IDE and SATA drives.
IBM Hitachi Feature Tool 2.15
allows you to control some of the features of the the HDD.
Maxtor amset utility 4.0
Utility for changing Acoustic Management on the hard drives.
Maxtor Low Level Formatter 1.1
Maxtor's Low Level Format Utility works on any harddrive.
Maxtor PowerMax 4.23
designed to perform diagnostic read/write verifications on Maxtor/Quantum hard drives.
MHDD 4.6
Precise diagnostic of the mechanical part of a drive, perform Low-level format, Bad Sector Sepair, access raw sectors, manage S.M.A.R.T. (SMART) and other drive parameters such as acoustic management, security, Host Protected Area, etc.
Samsung Disk Diagnose (SHDIAG) 1.28
to diagnose the disk when suspected to have failures.
Samsung ESTOOL 3.01v
Drive Diagnostic, Automatic Acoustic Management, Enable/Disable SMART etc.
Samsung HDD Utility(HUTIL) 2.10
The Drive Diagnostic Utility.
SeaTools for Dos
GUI 2.22 Text 1.10 versions to test Seagate or Maxtor Parallel ATA (PATA and IDE) and Serial ATA (SATA) interface disc drives.
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
Toshiba Hard Disk Diagnostic 2.00b
Toshiba hard drive diagnostic utility.
Victoria 3.33e and 3.52rus
a freeware program for low-level HDD diagnostics.
Victoria 4.46
Universal program for testing storage devices
ViVard 1.0
HDD low-level diagnostics, Surface test with remap, SMART-attributes etc.
WDClear 1.30
Restore/Erases the drive back to a factory condition.
Western Digital Data Lifeguard Tools 11.2
for the installation of Western Digital EIDE Hard Drives.
Western Digital Diagnostics (DLGDIAG) 5.19
to quickly and efficiently verify the status of the drive.
Western Digital Data Lifeguard Tools 1.22
to perform drive identification, diagnostics, and repairs on most WD drives
BellaVista 1.1.0.54
Formerly BCD Editor with lots of options to configure Windows for a developer.
Boot Partition 2.60
add Partition in the Windows NT/2000/XP Multi-boot loader.
BootFix Utility
Run this utility if you get 'Invalid system disk' message.
BootSect 6.0.6
Boot Sector Manipulation Tool, This tool replaces FixFAT.exe and FixNTFS.exe.
BootICE 0.80.6
a boot sector manipulation utility.
DiskMan 4.2
all in one tool for cmos, bios, bootrecord and more.
FbInst 1.6
More info's:
http://newsapp.info/software/hiren%27s-bootcd-13-0-download/
*This CD is NOT a Freeware because contains some unlicensed commercial software and the use of unlicensed software is illegal, this is just an example of multi boot, you can also create your own customized CD.
Hiren's BootCD 13.0
neerajrawat1
    • Experts Galaxy
Re: Hiren's BootCD 13.0
« Reply #1 on: 04. January 2011., 14:43:32 »
hmm nice one with updated apps its a very famous cd still never used this,hope to try next month size must be a dvd one
qwertysan
« Reply #2 on: 06. January 2011., 20:16:57 »
 :) nice updates. used this alot. though since hiren's boot 12 alot of programs "missing".
krrjhn
« Reply #3 on: 11. January 2011., 07:53:39 »
Nice updates!!
