  • Total Topics: 17027
  • Online today: 68623
Guests: 63588
Total: 63588
Author Topic: Windows 7 SP1 RC uninstallation  (Read 6888 times)
arvind79
  • Knowledge is Wealth, Everything is for Good
    • http://mGinger.com/index.jsp?inviteId=4162716
« on: 28. February 2011., 06:01:48 »
hi,
i am using windows 7 with service pack 1 rc version 721. now recently i tried to upgrade to service pack 1 final version it won't upgrade because i used disk cleanup in windows weekly once. i tried to uninstall in control panel under the option installed updates it has not appeared. help me with your ideas.
Thanks & Regards
Aravindhan K
Instructions how to upgrade Windows 7 over the RC or Beta version
« Reply #1 on: 28. February 2011., 19:39:55 »
Hi pal.
Here's the procedure (for 1st. try): ;)
   1. Download (make) the ISO and burn them to a DVD.
   2. Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
   3. Browse to the sources directory.
   4. Open the file cversion.ini in a text editor like Notepad.
   5. Modify the MinClient build number to a value lower than the down-level build. For example, change 7100 to 7000 (pictured below).
   6. Save the file in place with the same name.
   7. Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
Please, provide us info did you (also) success with this instructions or maybe need additional help?
cya,
P.S.
Don't forget to, before anything, make backup! Just in case...
 :police:
amko_sa
    • Newsapp IT support Portal
Re: Windows 7 SP1 RC uninstallation
« Reply #2 on: 28. February 2011., 21:50:55 »
What error do you have when you try to install sp1 rtm and can you write error from error log in cp?
Rosie667
« Reply #3 on: 12. April 2011., 08:12:36 »
Windows 7 Service Pack 1 (SP1) contains many updates to improve Windows 7, but if you encounter a problem with hardware or a program after installing the service pack, you might want to temporarily uninstall it to troubleshoot the problem.
