Well.. first thing is to disable autorun, then you might want to access the pendrive via system console.there I suggest you to do a dir /a to see what's actually in there, after that proceed to delete unwanted files, starting by autorun.iniAnyway, if you can create a compressed file with all of the pendrive's content, you can sumbit it to AVERT lab so they provide a extra.dat for you (wich can be deployed via ePO) and eventually will be included in a official DAT Release.
(if you can create a compressed file with all of the pendrive's content, you can sumbit it to AVERT lab so they provide a extra.dat for you (wich can be deployed via ePO) and eventually will be included in a official DAT Release.)
1. If you did not format your flash drive, then check whether the files are not in hidden mode (Go to folder options-> view tab and uncheck the option of “Hide protected operating system files(Recommended)).2. Click on "Start" -->Run-->type cmd and click on OK.3. Enter this command: attrib -h -r -s /s /d g:\*.*Note : Replace the letter g with your flash drive letter.4. Now check for your files in Pen Drive.5. After that, download the Malwarebytes' Anti-Malware and run Full scan: http://scforum.info/index.php/topic,2201.0.html
thank you guys for the help and will let you know the result later ... have a nice day to all of you ...
Quote from: metalmunna on 05. May 2011., 02:13:10thank you guys for the help and will let you know the result later ... have a nice day to all of you ...Any news about this case, MM??
Quote from: Samker on 09. May 2011., 19:36:23Quote from: metalmunna on 05. May 2011., 02:13:10thank you guys for the help and will let you know the result later ... have a nice day to all of you ...Any news about this case, MM??... still i didn't get that virus file which isn't detected by McAfee Enterprise (that's not fake coz i saw that too on their pen drive before), but they sent me some files yesterday but that's already protected by McAfee .. so waiting for the files which was cause of the Pen Drive ..
