National Geographic is one of the largest non-profit scientific and educational institutions in the world.
Over the years, it has also been a great source of amazing photos and wallpapers that mesmerized people from around the globe.
Some of the most beautiful wallpapers have been placed online, on the National Geographic website, but due to their large number, downloading them has been a problem until now.
With NatGeo Wallpaper Downloader you can download over 5000 National Geographic wallpapers with just one click.
Future builds will add even more packs like: History, Adventure, Traveler, Sea Monsters, Seabed, Blue Earth, Green Earth, Forces of Nature, Lewis & Clark, Roar and many more! (As you can see, I have my hands full, so don't miss out on these great wallpapers when they'll be added!)
Be advised: Downloading wallpapers can take a while if you're on a slow (modem/ISDN) connection! If you're not using a high-speed connection I'd advise you to download the wallpaper packs one by one.
Usage:
Take a look at both categories (Natgeo Magazine Walls & Natgeo Website Walls)
Check the collections you'd like to download
Select the resolution for each collection (if you're not sure of your screen's resolution, press Get Resolution)
Select the download folder (if you don't want them being placed on the desktop)
Press Start Download!
Using the National Geographic wallpapers to create a screensaver
In Windows XP
Open Control Panel (from the Start menu)
If you're in Category View, click Appearance and Themes and then Choose a screensaver
If you're in Classic View, run Display
In the Screen Saver tab, select My Pictures Slideshow from the drop-down menu and click Settings
In the My Pictures Screen Saver Options window, click Browse, select the path you chose in NatGeo Wallpaper Downloader as download path and then OK to close the window
Press Apply and OK in the Display Properties window
See here the main steps described above
In Windows 7
If you're in Category View, click Change the theme
If you're in Icons view, click Personalization
Click Screen Saver in the bottom right on the Personalization window
In the Screen Saver Settings window, select Photos from the drop-down menu and click Settings
In the Photos Screen Saver Settings window, click Browse, select the path you chose in NatGeo Wallpaper Downloader as download path and then Save to close the window
Press Apply and OK in the Screen Saver Settings window
Close the Personalization window
Download: --- below, Devvie's post ---Source:www.apps.nozavi.com
--- edited by Admin ---
