  • Online today: 88118
Guests: 67208
Total: 67212
Author Topic: Vista Codec Packs  (Read 16913 times)
Vista Codec Packs
« on: 28. July 2007., 18:54:19 »
Vista Codec Package 4.4.8 Final
Codecs have always been a pain in the butt. This package takes from the best, all the big name creators, several small guys too, and compiles all this into a single pack. All possible conflicts are already dealt with, many user suggested default settings are implemented.
This package does not contain a media player. This package does not associates filetypes. With this package installed, you will be able to use any media player to play DVD´s, movies and video clips such as quicktime, realmedia, avi, mpeg, Flv, swf, wmv, etc. Streaming video can be played within web browsers. By default, you shouldn´t need to make any adjustments to enjoy playback immediately.
Users now have the ability to choose what is installed using the public redistributable and after an unattended install, you can select to remove specific portions without removing the entire package. Future releases will recognize previous releases and perform upgrade installations.
This package contains QuickTime v7.1.3 components with the tray icon permanently disabled.
This package currently supports 15 localized installations: The default install is English including support for the following other languages; Chinese Simplified/Traditional, Japanese, Czech, Dutch, French, German, Greek, Italian, Portuguese, Russian, Spanish, Polish and Turkish.
changelog:
fix black+white issues with some .avi files
fix .WMV support broken in alternate players after installing WMP11
add new component, Koepi´s XviD Codec 1.1.2
update Haali components to v1.6.338.23
update FFDshow components to t494
fix Vobsub shortcut
Download:
Vista Codec Packs
Vista Codec Package 4.4.9 Final
« Reply #1 on: 24. August 2007., 22:13:54 »
With Vista Codec Package installed, you won't need to install any other codec or filter. Many user suggested default settings are implemented. It does not contain a media player. It does not associates filetypes. With this package installed you will be able to use any media player (limited only by the players capabilities) to play DVD's, movies and video clips of any format. Streaming video (real and quicktime) is supported in web browsers. Visit the homepage to get a 64bitAddon which enables xvid, divx and DVD playback in Vista's MediaCenter.
Kaldata
Download: http://www.majorgeeks.com/download5326.html
Branden Carothers
Re: Vista Codec Package 4.4.9 Final
« Reply #2 on: 06. September 2007., 18:27:12 »
But does this help play files with the divocodec? Cant play any files under that codec. cant find a player.
« Reply #3 on: 06. September 2007., 19:26:31 »
Hi Branden,
here you can find more information about "divocodec": http://go.divocodec.com/
But, it's look like that Codec & Player isn't safe (maybe that is some kind of Malware, as I now "googled").
I don't want to scary you but did you check that file carefully?
P.S.
We also provide here few FREE Online PC Scans like (Kaspersky, McAfee, Symantec ...) try them.
Also if you have any question more about Divocodec & Security just ask, we are to help you.
gaz
« Reply #4 on: 30. September 2007., 09:53:05 »
Hello there,
This codec dose not work on Vista DivoCodec sigh, what can I do please help!!!!!
Gaz
« Reply #5 on: 30. September 2007., 11:17:01 »
Hi Gaz.
Welcome to SCF Community.
Did you already visit official DivoCodec site?
P.S.
Scan that player carefully:
Vista Codec Package 4.5.1
« Reply #6 on: 13. October 2007., 07:23:23 »
With this package installed you won't need to install any other codecs.
When dealing with codecs, more does not equal better.
Having the least amount on your system is the best configuration.
This is exactly what the Vista Codec Package does for you.
You will no longer be restricted to using a specific player.
Windows MediaPlayer and Vista MediaCenter will be able to play all your files.
This page is updated often with new information, Tools, and BETA releases. Visit regularily and stay informed.
Troubleshooting installation problems
VISTA USERS: please research User Account Control
Users may choose to use this program to temporarily disable UAC
and then right-click on the downloaded installer and choose 'Run as administrator'
When installing VCP you must choose the language that matches your operating system.
To solve the issue, re-install the same version that's on your system with the correct language.
To correct this issue, download and execute the latest installer and it will offer to UPGRADE your current installation.
If you . . .
- are receiving an error message about xvidcore.dll installing the current release will correct it.
- have COM_Surrogate errors, upgrade any DivX products you have with a current release. Upgrade Nero to 8.x
- installed XviD or FFDshow on your own other than the versions included in this package may also cause issues.
- have problems with the functionality one specific program, try installing it AFTER the codec package to resolve it.
Audio output and Speaker setup (Vista)
for DVD settings and audio such as AC3 Dolby Digital 5.1 surround
Open the AC3filter configuration shortcut, in the upper left you will see, Output format -
the default setting is : AS IS (no change) ..... you may set it as you wish.
All other audio playback
Open the Audio decoder configuration shortcut, scroll the left window down to 'Mixer',
place a check in the 'Mixer' box, and in the righthand window select you speaker setup in the drop down list
Then check the box for LFE if you have a subwoofer attached.
To use SPDIF output
Go into Vista's Control Panel and navigate Sound/SPDIF/Properties/Advanced/Exclusive Mode
(depending on your sound device, the above path may be a bit different but similar)
Then CHECK the box
  • for the following 2 items
'allow applications to take exclusive control of this device'
'give exclusive mode applications priority'
If you are experiencing choppy or stuttering sound
Go into Vista's Control Panel and open the Sound applet
Select your output device in the list that appears
NOTE: the default output device is commonly labeled Speakers
Right click on the device and from the context menu click Properties.
Click on the Enhancements TAB.
Then CHECK the box
  • for Disable all enhancements.
NOTES on certain types of playback
If Windows fails to playback DVD's install Media Player Classic from the Tools section below to play DVD's.
Some MPEG (mpg) files will require you to use the shortcuts provided for CLASSIC playback and vice-versa to MODERN.
If you change the MOV file extension to HDMOV you will improve the quality of the video playback.
To playback *.ASF files in Vista's MediaPlayer 11 or MediaCenter change the file extension to ASX.
To playback *.VOB files in Vista's  MediaPlayer 11 or MediaCenter change the file extension to MPG.
To playback *.MOD files in Vista's  MediaPlayer 11 or MediaCenter change the file extension to MPG.
Download: http://download.softpedia.ro/dl/f12f6423fc26029d48391d8d2feba54d/47108b76/100055586/software/MULTIMEDIA/VIDEO/DIVX/VistaCodecs_v451.exe
(Copyright by MSFN.org)
http://www.jtow.net
Vista Codec Package 4.5.3 Final
« Reply #7 on: 18. November 2007., 17:17:35 »
DOWNLOAD: http://www.majorgeeks.com/download5326.html
(Copyright by MSFN)
http://www.msfn.org/board/index.php?showtopic=66826
Vista Codec Package 4.5.5 Final
« Reply #8 on: 21. December 2007., 07:37:13 »
With Vista Codec Package installed, you won't need to install any other codec or filter. Many user suggested default settings are implemented. It does not contain a media player. It does not associates filetypes. With this package installed you will be able to use any media player (limited only by the players capabilities) to play DVD's, movies and video clips of any format. Streaming video (real and quicktime) is supported in web browsers. Visit the homepage to get a 64bitAddon which enables xvid, divx and DVD playback in Vista's MediaCenter. Licence: Freeware.
DOWNLOAD: http://fileforum.betanews.com/detail/Vista_Codec_Package/1159994557/1
