  • Total Topics: 15520
  • Online Today: 718
Author Topic: TrustPort USB Antivirus (download)  (Read 3108 times)
« on: 18. September 2011., 07:30:21 »
The mobile solution for the secure transmission of data on interchangeable memory media for example flash disks or memory cards. Prevents the copying of harmful code onto memory media, carries out antivirus tests on any host computer. Enables the encryption of files against unauthorized entry and offers the reliable shredding of private data which is no longer in use.
Antivirus protection
As soon as the memory medium is connected to a given computer the resident protection is activated. This prevents the storing of harmful code on the given medium. So you don’t have to worry that while using a computer with an unknown level of security your USB flash disk or memory card will be infected.
Scanning on demand
According to your needs you can launch a scan of the computer on which you are working with your portable memory media. In the event of harmful code being found, the file will be renamed, moved to quarantine or deleted depending on the settings.
Proactive protection
Between the arrival of new harmful code and its classification in the virus database there is a critical period when the computer is most vulnerable. Fortunately this antivirus program is able to recognize a virus not only from the database but also on the basis of its structure and behaviour.
Encrypted data
The program enables sensitive data to be stored in the encrypted archive of a USB flash disk or memory card in case of loss or theft. The creation and extraction of data from the archive, entry and deletion of files are all at your disposal in the form of the intuitive interface.
Secure shredding
It is important to delete sensitive confidential data after it is no longer in use in a way that no one can reconstruct it. For this task the program offers secure shredding as the disused files are repeatedly overwritten with random data. You can choose from eight levels of security in shredding.
Universal use
The program isn’t installed on the computer’s hard drive but on a separate memory medium. This medium can be for example a USB flash disk or a memory card in any format. It is just as easy to install the program on a U3 smart disk. This comprises a special version of the USB flash disk with its own administrator program used for the transfer of personal data and live applications.
Download (30-day Trial version)
: http://www.trustport.com/en/products/trustport-usb-antivirus
Win 1-Year license, more info's: http://scforum.info/index.php/topic,6881.0.html
