  • Total Topics: 16528
  • Online today: 3114
Guests: 3035
Total: 3037
Author Topic: How to remove a computer virus?  (Read 10652 times)
Jemshads
« on: 30. November 2011., 21:28:02 »
I have a virus on my computer which does not lets me go online,run cd's/dvd's or recognise usb drives.
It says system infected virus removal in progress don't shut down????
What should i do????it doesn't even lets me get in safe mode as well.I have tried resetting ie as well but still it says cannot display the web page.
Help needed guys...
Re: How to remove a computer virus?
« Reply #1 on: 01. December 2011., 01:19:33 »
Help needed guys...
Please give us a bit of information about your system, to say:
OS, Ram, processor, Hard Disk capacity, partitions, drives, and everything you think may be of importance.
Oh! Also do mention your AV, firewalls and such.
J.
Re: system infected virus removal in progress don't shut down
« Reply #2 on: 01. December 2011., 07:29:23 »
Help needed guys...
J.
Very hard infection, probably some Rogue AV. How and when this problem occur??
ASAP, provide us information which "jheysen" request, including installed AntiSpyware(s)??
Additionally, did you try to use "System Restore" option??
amko_sa
    • Newsapp IT support Portal
« Reply #3 on: 01. December 2011., 09:19:09 »
Try to download combofix from this link:
http://www.bleepingcomputer.com/download/anti-virus/combofix
After that you must disable your antivirus and disconnect computer from internet.
Run combofix and scan your computer.
When your computer is scanned and restarted with combofix, you must check virus definition for your antivirus and also download Malwarebytes from this link: http://www.malwarebytes.org/
Enable your antivirus and update virus definition.
Scan your computer with malwarebytes and clean everything that malwarebytes found.
Thats it.
vishwanath99
« Reply #4 on: 02. December 2011., 05:21:08 »
First he has to repair his OS then try to download and install combofix..
May be his OS is totally corrupted
« Reply #5 on: 14. February 2012., 22:41:39 »
Again, troll :s
War!
Dev Nullius
Raman11
« Reply #6 on: 22. April 2012., 22:11:33 »
I think your operating system is corrupted you can download combo-fix and install in your system. If the problem still remain in your system then format your windows by taking the backup of your important data.
lopezsimmon
« Reply #7 on: 01. September 2012., 14:42:36 »
If the virus is not much powerful and you found that the file which has virus than you can remove that file to remove virus as well. Or you can also install the antivirus to remove computer virus.
manual2100
« Reply #8 on: 21. September 2012., 11:54:46 »
you should try gmer or TDSkiller first to remove the rootkit and then do a virus/trojan scan
jmoon
« Reply #9 on: 30. June 2013., 22:13:23 »
Help needed guys...
On another computer try to download Bitdefender rescue disk or Avast or AVG rescue disk and boot from CD on infected computer and make sure once on the rescue cd environment to update the av and run the full scan.
